Right Rear Window Issue...
Old Aug 21, 2013 | 03:41 AM
epfire#233's Avatar
epfire#233
The right rear window isn't opening when pressing the overhead switch. The left window is operating just fine. I can't hear anything when depressing the switch. Any ideas as to what might be the issue and possible solutions for a fix? This is the far right vented window near the back of the vehicle.
Thank you in advance!
Old Aug 21, 2013 | 03:48 AM
MURDOMINO's Avatar
MURDOMINO
best way to determine if there is a bad switch, simply swap them from side to side, then you'll see if its a circuit issue with the right side, or hopefully just a bad switch with worn contacts.
Old Aug 21, 2013 | 04:20 AM
epfire#233's Avatar
epfire#233
Thank you for the advice Murdomino! I will give that a shot.
Old Aug 21, 2013 | 07:18 AM
Romanova's Avatar
Romanova
Try using the existing switch and have someone gently press outwards on the window while you press the switch. The seal can get nasty and the motor doesn't have enough power to overcome the seal. If it opens using this method, condition the seal with a product like 303 Aerospace Protectant (I use it on all my seals, weatherstripping, and tires).
303 Aerospace Protectant 32 oz.
Old Aug 21, 2013 | 08:25 AM
VaSheriff's Avatar
VaSheriff
If I recall correctly..... one works without the key being on, one has to have
the key on to operate. At least that's how I think my Excursion was.
2lionel
Oct 11, 2011 09:05 PM
bememe
2004 - 2008 F150
Sep 3, 2009 10:28 PM
berry1234
Jun 21, 2008 09:18 PM
RockyMtnRanger
Mar 6, 2008 07:22 PM
BatteriesNotINCL
2004 - 2008 F150
Oct 19, 2007 06:30 PM
