Tire rotation?
Old Aug 20, 2013 | 11:55 PM
expydaddy's Avatar
expydaddy
Tire rotation?
Hello all. I got a new set of tires put on about 7500 miles ago. When I had it aligned, I also had them rotate the tires for an extra nominal charge.
Now the Haynes says to go criss cross, they went front to back. On top of that they didn"t adjust the tire pressures.
Anyway, which is procedure is correct? The criss cross method. Rears to opposite corners to the front, the fronts just drop back to the rear.
Or, front to back only with no crossing over? I thought that was the method for f.f. cars.
I know Alloro knows the answer to this one.
I just want to know if the tongue lashing I plan on giving the Service Manager is warranted or not.
Thanks again
Old Aug 21, 2013 | 11:08 AM
2trux's Avatar
2trux
I've always heard that with radials you should go front to back on the same side.
Old Aug 21, 2013 | 03:29 PM
alloro's Avatar
alloro
If the tires have a rotation direction arrow on them then only rotate them front to back. If there is no arrow then then can be rotated crisscross.
kctickbait
1983 - 2012 Ranger & B-Series
Sep 18, 2017 09:07 PM
GeneLaw1
Feb 29, 2012 12:21 PM
lasmacgod
Jun 24, 2010 01:14 PM
dkf
Jul 29, 2008 03:49 PM
Lane Dexter
Nov 8, 2004 04:15 PM
