2003 Expedition A/C Question
Old Aug 21, 2013 | 05:22 AM
ltng7679's Avatar
ltng7679
Just driving the 03 exp I purchased in GA back to CT. My wife's feet are getting wet with the A/C running. The condensate seems to be dripping fine below the truck. It looks like the black plastic housing over her feet is just getting so cold that water condenses on the outside and drips. Any solution to this?
Old Aug 21, 2013 | 06:39 AM
projectSHO89's Avatar
projectSHO89
Will she ride in the back seat?
Old Aug 21, 2013 | 11:05 AM
2trux's Avatar
2trux
Maybe some of that stick on insulation (ex. silvery bubble stuff). I think you can find this at auto parts stores.
Old Aug 21, 2013 | 03:25 PM
alloro's Avatar
alloro
Did you try raising the temperature off of full cold?
Old Aug 21, 2013 | 03:26 PM
alloro's Avatar
alloro
LOL, great solution.
Old Aug 21, 2013 | 05:54 PM
projectSHO89
Hey, if this were Saudi Arabia, the goat would automatically ride in the front and the wife in the back. That's how you tell them apart!
Old Aug 21, 2013 | 10:55 PM
Hamfisted's Avatar
Hamfisted
The fix is to put the TSB rubber elbow on the drain outlet. At highway speeds air pressure under the hood causes the condensation drain to back-flow around the outlet and into the insulation. Ford cut the drain outlet nipple too short and they fixed it in later years. Here's a post on another forum discussing it: Expedition AC drain elbow installation. I'm in south Florida, and as humid as it is down here, with normal drainage I get no condensation buildup while using the AC. The bottom of the housing is dry.
-Mike
dtlions15
Mar 26, 2009 12:20 PM
dirtriderdan
Jun 22, 2003 01:31 PM
WMostellar
Oct 29, 2002 09:10 PM
Idahoan22
23
Oct 1, 2002 03:59 PM
