timing..???
Old Jun 15, 2003 | 09:51 AM
crazy4Fords's Avatar
crazy4Fords
timing..???
i m pretty new at this but i have seen some work but i have fresh rebuild 429 in my truck which havent been fired in few months what shd i do before i fire it up? and i know i need number 1 piston on comprseeion and rotor pointing to number one on cap and what degree so i put the dampner to? 0 degree? or what? i m not sure about this.. there any way i can lube up engine before i fire it up and need some more info on timing and degree and what to watch befopre i fire it up the beast been waiting to be REBORNED!!! i installed a a 429 into my f250 4x4, email me if someone know anything about this?
Old Jun 16, 2003 | 05:22 PM
georgedavila's Avatar
georgedavila
timing..???
I use a 1/2" drill with an 18" shaft with a socke brazed on which fits over the oil pump drive shaft. Attach a mechanical oil pressure guage, pull the valve covers and run the drill until you have oil pressure and see oil coming out of the push rods.
You have the timing correct, it is TDC on the dampner. Advance it about 5 degrees for initial firing. Have you broken in the cam?
Old Jun 18, 2003 | 11:44 PM
Vin Man's Avatar
Vin Man
timing..???
I've done the same thing with the drill and it worked great. Just don't drop the littly clip thinging off the shaft and into the oil pan - not that I'm talking from experience or anything....
Old Jun 19, 2003 | 02:45 AM
ludis's Avatar
ludis
timing..???
Duct tape all the drill attachments together. That way, none of the pieces can drop off.
RUredE
Jul 30, 2009 10:28 AM
1947/67/77Ford
Sep 7, 2007 09:36 AM
woodlandwood
1997 - 2003 F150
Mar 8, 2007 12:38 AM
wesley958
25
Jan 2, 2003 02:21 PM
sturzinator
May 12, 2002 10:00 PM
