Bed Patch Panel?
Old Aug 20, 2013 | 01:54 PM
fordtrckman1977's Avatar
fordtrckman1977
Bed Patch Panel?
All of the patch panels I have been able to find are just straight louvered panels. Does anybody make one for the rear of the bed around the bolt where it changes shape? One side of mine has holes popping through around that body mount and I was hoping to find a panel. Its pretty impossible to find a bed down here in florida that isn't rough shape or I would just cut a piece out of one in a junk yard...
Old Aug 20, 2013 | 02:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Not quite sure which panel you're talking about. First, is it a styleside or flareside?
Old Aug 20, 2013 | 09:02 PM
paredneck33's Avatar
paredneck33
I think he is talking about the bed floor. and as far as I know all the aftermarket replacement floors do not have the flattened bolt area stamped in them. just the ribs or louvers as you referred to it straight back. at least that was how the aftermarket bed was that used to be on my 78 150 when I got it.
Old Aug 20, 2013 | 09:59 PM
march's Avatar
march
I think he means this. And I also need a replacement panel or ideas on how to fab something that works with the ribs.
By the way. Any ideas what would cause this. Same rot on both sides, rear near the tailgate. Truck was other wise had minimal rust issues
Old Aug 20, 2013 | 11:05 PM
KIKKUP's Avatar
KIKKUP
I'd say it would be best to find a salvage yard and see if they'll cut you some matching panels from a donor.
Old Aug 21, 2013 | 02:30 AM
fordtrckman1977
March hit the nail on the head. It's the bed floor around the rear mount bolt. My apologies for not being clear. As far as I can tell mine was probably rusted out due to lack of cleaning dirt and mud from around the mount. I haven't had much luck finding any of these trucks worth pulling parts off around here. Either way this donor beds a lot more solid than the one currently falling off my truck lol
Old Aug 21, 2013 | 10:08 AM
rogue40's Avatar
rogue40
That bolt is close enough to the seam to damage any sealer and open the seam a tiny bit.
Old Aug 21, 2013 | 08:43 PM
Blue and White's Avatar
Blue and White
A suggestion... go ahead and buy the louvered panel. Cut out the area that needs to be flat. Tack weld in a flat piece of steel. Slit the top corners of the louvers and fold down to the flat piece. Weld it solid. If you pre-clean the weld areas to steel, coat with weld through primer and seal well after it should last a ling time and look decent.
Old Aug 21, 2013 | 10:44 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
Look at later model beds!! up to the 90's you will notice the same exact bed floor. sawzall it out and have it welded in.
Use seam sealer at the overlap so it wont rust again.
Derfus
16
Oct 14, 2016 07:22 AM
dwil
Feb 12, 2016 10:39 PM
MdubbU
Apr 14, 2014 05:19 PM
bucks77ford
Jun 26, 2006 12:23 PM
ama chur
Jun 13, 2003 12:00 PM
