Odometer rollback issue
Old Aug 19, 2013 | 10:30 PM
93sc's Avatar
93sc
So I have a 95 F-250 w/ a 460. I have an issue with the odometer rolling back roughly 1.0 miles after I turn the key on after driving. It doesnt happen all the time, it doesnt depend on the length of the previous trip, matter of fact I havnt found anything consistant about it. Just so I'm clear, I will park the truck and look at the odometer which will read 180265.4 (for example), I turn the truck off, then turn the key back to the on position at which point the odometer will now read 180264.4. Thats an example from 2 days ago. Oh yea, digital odometer. However, sometimes it just reads the same mileage. This is something I havn't seen before, so I'm not sure what is going on. I just happened to look the other day when I was trying to figure out my mileage. And while it's a 460 I expected better than 4.5mpg. If anyone has an idea, I would really appreciate it.
Old Aug 20, 2013 | 06:34 AM
rla2005's Avatar
rla2005
The PSOM attached to the back of the speedometer stores the odometer reading. Pull it out and inspect for signs of leaking capacitors. The EPROM could also be bad.
Old Aug 20, 2013 | 06:38 AM
dixie460's Avatar
dixie460
Yeah, the Programmable Speedometer/Odometer Module is the only thing that stores the mileage. If it ain't working, you can pull it out and see if it's repairable. If not, then you can get another from a junkyard but unfortunately you won't be able to store your current mileage. If you can get one with lower mileage than you currently have on your truck, you can set it up on a bench and feed it a signal until it reads the same as your current one, then install it and go.
Old Aug 20, 2013 | 07:28 AM
Jarryd's Avatar
Jarryd
Just keep turning the key on till the truck has 30k on the clock and pawn it off for profit.
Not serious.
Old Aug 21, 2013 | 01:59 AM
93sc's Avatar
93sc
Thanks guys. Sounds like its time to hit the junkyard.
Old Aug 21, 2013 | 08:52 AM
Eddiec1564's Avatar
Eddiec1564
The EXACT thing happened to my 95 E350 bus PSOM!! It is the PSOM malfunctioning and its time to replace it. At least you was loosing a mile, mine was not saving milage when I turn off the truck, but would save mileage like every 9 to 12 miles...... It took me a while to figure that one out. I dropped from 8.5mpg to like 1 or 2mpg due to that malfunction...
Here's some threads that are about the PSOM:
https://www.ford-trucks.com/forums/1...r-display.html
https://www.ford-trucks.com/forums/1...splay-fix.html
TheKirbyMan
39
Sep 1, 2019 04:12 PM
don766
Feb 26, 2015 01:47 AM
kupaa
16
Jun 28, 2011 07:21 PM
chewyjackson
Sep 22, 2006 08:03 PM
littlelats
1978 - 1996 Big Bronco
Jun 2, 2004 01:21 PM
