1978 - 1996 Big Bronco
Digital odometer Error 3?
Old Jun 2, 2004 | 11:16 AM
littlelats's Avatar
littlelats
Hi All,
I recently purchased a 1992 Bronco Custom from the local sheriff's office. At the time of purchase, the odometer didn't work, but after replacing a fuse, it came back to life. But now it alternates between displaying the mileage and the words "Error 3." What does this mean and is there a way to reset the thing? I'm completely new to Bronco's, so any advice is appreciated. If possible, please email responses to me at: mberger@namginc.com
Thanks in advance,
Mike Berger
mberger@namginc.com
Old Jun 2, 2004 | 01:07 PM
djjoshuad's Avatar
djjoshuad
IIRC, this means that it's not the actual mileage. The computer knows that the truck ran for awhile without a functioning odometer, so it's trying to let you know that your mileage is incorrect. I could be wrong, but I'm pretty sure that's what I read when I was researching speedo recalibration.
-Josh
Old Jun 2, 2004 | 01:13 PM
littlelats's Avatar
littlelats
Josh,
Thanks for the advice. That was the same conclusion that I came to. I know the sheriff's office drove the vehicle around the parking lot a few times, but other than that, the mileage is very close to that stated. Do you know a way to make the "Error 3" message go away? Does holding the rest button in while turning the key to the run position have any effect?
Thanks again,
Mike Berger
Old Jun 2, 2004 | 01:21 PM
djjoshuad's Avatar
djjoshuad
I believe that it will clear itself if you go into the dealer program mode... although I'm not sure. It's worth a try. There is a jumper you need to ground, then turn the key while holding reset... try this website:
http://www.broncodata.com/tech/speedcor.htm
it shows you how to get into that calibration mode. It may not fix your problem, but it may be a step in the right direction.
-Josh
