390 hp rating???
Old Aug 19, 2013 | 10:15 PM
74scsp's Avatar
74scsp
390 hp rating???
can anyone tell me what kind of hp a 74 fe390 makes, edelbrock 700 cfm?? compared to a 60's version? it came out of a 79 f150. was 4 spd truck. but was not original drivetrain.. casting number on block is D4TE i believe.
Old Aug 20, 2013 | 06:50 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Well if it was an "R" code it would be 425 hp!
Old Aug 20, 2013 | 08:20 AM
bertha66's Avatar
bertha66
Most of the 300's of the 1960's with a stock 4bbl carb ran 300hp rating. The Fairlanes GT's in 66 and 67 had 335hp. the 1960's 390's with 2bbls ran about 290hp.
The D4 number you give would be in for a 1974. I'm not should of HP ratings on the later engines
Old Aug 20, 2013 | 08:17 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by 74scsp
can anyone tell me what kind of hp a 74 fe390 makes.
In stock form a lowly 195hp (net)
By the 70's the 390 was a mere shadow of its former self, suffering from low compression, low lift cam and smog era junk.
The 60's 390's (4bbl) were typically in the 300-335hp range with a few notable exceptions.
Major Engine Specifications -- The Ford V-8 Engine Workshop
Old Aug 22, 2013 | 01:58 AM
74scsp's Avatar
74scsp
I was told it was rebuilt at a local speed shop, so if i did a compression test, and got numbers in each cylinder of 180 psi, would it be safe to assume its not a stock 74 spec motor?
Old Aug 22, 2013 | 09:58 AM
keiths78f150's Avatar
keiths78f150
I cant help with the horsepower rating, but I can teach you how to not use all bold huge letters.
Old Aug 22, 2013 | 11:55 AM
montana_highboy
That would be a safe assumption...
140 psi~8:1
150 psi~8.5:1
160 psi~9:1
170 psi~9.5:1
180 psi~10:1
190 psi~10.5:1
200 psi~11:1
If the motor was rebuilt to stock specs you'd see around 140 psi +/-
riverguideguy
Aug 6, 2013 10:11 PM
Plums72
Mar 23, 2010 09:55 PM
72sportcustom3906.4l
Apr 28, 2009 09:15 PM
lifted77f250
165
Aug 27, 2006 07:21 AM
biz4two
26
Jan 20, 2004 06:33 AM
