Periodic chug in the engine
Old Aug 19, 2013 | 04:53 PM
150jason's Avatar
150jason
I have a 2005 Exploer Sport Trac with 236K on it
recently changed all plugs & wires as well as the coil pack to stop a sputter in the motor. it worked. now, very periodically and only for a split second i will loose all rpm and then back up again to normal. I was told that the computer may be going but i've plugged it in and it wont turn on a reader. other than that one hickup she runs like a dream now. can anyone help.
Old Aug 19, 2013 | 11:06 PM
KhanTyranitar's Avatar
KhanTyranitar
Forget high tech wizardry, check your engine and chassis grounds. A bad connection can cause all sorts of electrical mischief.
Don't listen to people that tell you the computer is burned out, PCM failure is actually pretty rare.
Trav101
Modular V8 (4.6L, 5.4L)
Jan 19, 2015 07:23 AM
mjunk1
1997 - 2003 F150
Nov 1, 2010 12:21 PM
Bill's2000X
Modular V10 (6.8l)
Oct 21, 2010 11:10 PM
gizman2
Sep 11, 2005 12:29 PM
Ed_ManINWa
Mar 15, 2004 10:04 PM
