carter 1 barrel issues, continued...
Old Aug 17, 2013 | 05:59 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
so, forthose of you who are following, i am STILL having issues with my carter 1 barrel on Clyde, my 1981 F150 with a 300, auto, 2wd.
I had the carb rebuilt, they did a nice job, bead blasted everything, re-bushinged the throttle shaft, and i dropped the carb on, tuned it, and was set. I drove the truck daily for 2 weeks straight, getting an average between 16 to 18 mpg. i was pleased.
One day, leaving work, i got about a block away from work, the truck acted like it was choking, and i pulled over to a nearby parking lot. As i opened the hood, i was greeted with fuel running down the side of the carb and down the manifold. after putting the truck on the trailer ( i hate putting the truck on the trailer, btw, its humiliating) i got it home, plucked the carb, and sent it back to the carb guy. he went and gave it once over, and gave it back a week later with a few new gaskets. Bolted it on, same luck. he came, watched it act up on the truck, and tore it apart that night, still acting up. He decided to take it back with him, completely rebuilt it, and here i sit, with it acting up yet again.
So, my carb guy is flustered, and im frustrated with a truck that i cannot drive. I wired the choke plate wide open, to make sure there is no possibility of the choke flopping shut, creating issues.
so, anyone have any ideas, smart remarks, or other suggestions? im kinda stumped....
Old Aug 17, 2013 | 06:16 PM
JWC 3's Avatar
JWC 3
What is it doing now ? excess fuel running out all over the place ? What is your fuel pressure ? What type of fuel pump ? If fuel is " running over " you have a needle/seat issue , float level issue , or too high fuel pressure . Last I would think , a porous carb body that needs replaced .But.... without seeing it in person.. just a guess . Good luck , hope it helps !
Old Aug 17, 2013 | 06:22 PM
Bootlegger's Deluxe
fuel is running out of the top bowl vent. it will run for approx. 20 seconds, then flood out. fuel pump has not been verified for pressure, it is a factory replacement pump from NAPA, about 8 months ago.
I was thinking about a needle or float issue, but i have no clue on the inside of this carb and its workings. I did a few holleys a number of years ago, but i tore this one apart, discovered its nothing like a Holley, and had my carb guy go through it.
Old Aug 17, 2013 | 06:32 PM
Bootlegger's Deluxe
Old Aug 17, 2013 | 06:37 PM
Gary Lewis's Avatar
Gary Lewis
I think I explained my experience back in '69 wherein a tank of bad gas did exactly that to my Holley. Anyway, if it isn't too high of pressure then it may be something in the tank, something gooey that causes the needle to hang up. (I'm assuming your carb guy has already ensured that you are running a good filter so it isn't grit.)
Old Aug 17, 2013 | 06:42 PM
Bootlegger's Deluxe
i put on a clear, rebuild able glass fuel filter on it, so not only am i filtering the fuel, i can also visually check the condition of the fuel itself.
Anyone know what fuel pressure my pump should be putting out?
Old Aug 17, 2013 | 06:50 PM
Gary Lewis's Avatar
Gary Lewis
W/o looking it up, the Edelbrocks like below 6, but the stock pump can put out something like 8 psi - if I remember correctly.
Old Aug 17, 2013 | 07:10 PM
JWC 3's Avatar
JWC 3
4-6 psi is spec for your engine .
Old Aug 17, 2013 | 07:20 PM
Bootlegger's Deluxe
heres to hoping my fuel pressure tester reads that low
Old Aug 17, 2013 | 07:26 PM
JWC 3's Avatar
JWC 3
You will need an old school gauge to read these pressures . A injection pressure gauge will be no use at these low pressures .
Old Aug 17, 2013 | 07:34 PM
Bootlegger's Deluxe
i thought i saw that my vacuum gauge possibly will work as a mechanical pressure tester.. that sound right?
If so, how exactly do i do that?
Old Aug 17, 2013 | 07:39 PM
JWC 3's Avatar
JWC 3
possible . I have a vac gauge that is also a pressure gauge . Old , but still works . Have not used as a pressure gauge in years . That was standard , years ago . Heck , I still have a timing light and feeler gauges !
Old Aug 17, 2013 | 07:42 PM
Bootlegger's Deluxe
thats what i have too... i think it was my pops from his wrenching days in the early 80's... now, how do i hook it up?
Old Aug 17, 2013 | 08:01 PM
Gary Lewis's Avatar
Gary Lewis
Put a tee in the line between the pump and the carb.
Old Aug 17, 2013 | 08:02 PM
JWC 3's Avatar
JWC 3
Wow , some adapting , reducers , hook to fuel line , good to go . Years since I used it that way ! Test pressure at pump outlet , should be self regulating , if out of spec there is a problem .
