Cleaning the belly
Old Aug 17, 2013 | 05:26 PM
axehandle's Avatar
axehandle
Cleaning the belly
Tell me about cleaning the underside of these beasts. My '55 F100 looks like it lived in a barn and was driven on a dirt road all it's life. Not doing a full up restoration or anything like that just want to touch it up a bit mechanically and cosmetically and drive it. Do I need to soda/sand/water blast this stuff off the entire underside and then paint or will removing it just encourage the metal to rust?
Old Aug 17, 2013 | 06:35 PM
HkyswiM's Avatar
HkyswiM
If your not taking the body off I would pressure wash it since sand blasting is very messy. My suggestion would be to pressure wash, clean the frame up with some form of abrasive like a grinder with a wire brush attachment or just a wire brush to knock off the loose rust, then coat it with something like a por-15.
It won't hurt to do this, even if you don't cost the frame. All that old dirt can keep moisture in it and rot the frame that way, so I would get as much out as you can.
Old Aug 17, 2013 | 07:28 PM
56panelford's Avatar
56panelford
I'd pressure wash it and if you have access to a needle gun ( like what's used for descaling welds ) they do a very good job of cleaning off rust, even the fine rust. Then use por15 products
Old Aug 17, 2013 | 10:30 PM
FortyNiner's Avatar
FortyNiner
A little time with a a wire brush or wire wheel - wear eye protection! - will do a tremendous amount of good. The pressure washing is a fine idea - unless you have a lift, getting access with a wash gun can be problematic.
DW
Old Aug 17, 2013 | 10:43 PM
my 66's Avatar
my 66
clean
The pressure washer is the way to go. Highest pressure you can get. 4000psi. after that i would spray it with a degreaser like purple power. Wire brush any spots with heavy dried grease. Then re pressure wash. Let dry completely then coat with por15 or what i use kbs. Kbs come in a few colors which i fine better. Kbs also has a liquid blast you use before the kbs rust seal. Good luck and enjoy your truck
Old Aug 18, 2013 | 12:45 AM
aussiecowboy's Avatar
aussiecowboy
Hire a steam cleaner/hot wash, nothing else will get years of baked on road grease and grime off like it.
Old Aug 18, 2013 | 07:37 AM
56panelford
The needle gun actually does a better job than a wire wheel and is much safer than having pieces of wire flying at you.
telewinder
Nov 10, 2017 09:44 PM
48' fordster
Dec 5, 2007 01:27 PM
crazymike
16
Oct 9, 2006 10:31 PM
don_79f250
General Automotive Discussion
May 17, 2004 08:55 AM
Greywolf
Garage & Workshop
Aug 22, 2002 10:39 PM
