Stuck 360..please help?
Old Aug 17, 2013 | 12:22 PM
Airborn2001's Avatar
Airborn2001
Hi all,
I'm new to these engines, and nobody around here seems to be into old fords, so I'm looking for advice. I have recently acquired a 1976 F-150 with a 360 bored .030 over and slight cam. Apparently the truck ran great until it sat for 3 years and now it's stuck. We pulled the spark plugs out and one was very rusty. Shot transmission fluid into the cylinders and let it sit a week before trying to turn it by hand, but it's still stuck.
Is it worth getting the engine unstuck, and if so, any advice on a better way to do it? Do these engines have any re-sale value?
I'm not looking to spend a lot, as the engine will not be in the truck forever.
Thanks in advance!
Old Aug 17, 2013 | 05:20 PM
jowilker's Avatar
jowilker
Sounds like the rusty one has a head gasket leak causing the lockup. You are likely going to have to pull the head on that side anyways. Do that then decide. A stuck 360 can bring a couple hundred. It is a good 390 rebuild setup.
John
Old Aug 19, 2013 | 11:04 PM
Redmanbob's Avatar
Redmanbob
Originally Posted by Airborn2001
Hi all,
Thanks in advance!
Pull the valve train on both sides and then try it. If it's still stuck, then it is going to be a lot of joy.
Old Aug 20, 2013 | 11:45 AM
Freightrain's Avatar
Freightrain
Welcome to the forums.
Likely rusty cylinder(s). Might break it loose, might not? All depends on how much you want to tear it down to get it loose.
360's are not big ticket items. Especially if one/more cylinders are rusted up badly. Might get it running good, might burn oil due to bad rings/pitted cylinder walls.
Old Aug 20, 2013 | 11:08 PM
76monstercreator's Avatar
76monstercreator
Hi, I am new to this, but you guys have helped me so much over the years and upon my newest project i figured i would join.
Try Marvels Mystery Oil, seriously. pour a generous amount in each cylinder and let sit for bout 2 days and just slowly work it back and forth. Its a pain but if you dont want to rebuild, thats what i would do. I used a 3/4" breaker bar, and back and forth, for bout an hour and i started getting a little movment and then a little more. I broke mine free and had to tear it apart anyway, bad bearings. But Best of Luck
P.S. If you do go this route use caution it does make a rather HUGE mess. put rags over the spark plug holes, invest in some floor dry.
Old Aug 21, 2013 | 09:01 AM
MIKES 68 F100's Avatar
MIKES 68 F100
If it's really stuck you want to pull the heads , breaking loose can cause a ring to break and destroy your cylinder walls .
ige1963
Nov 8, 2018 02:19 AM
Chuckles2
May 24, 2017 10:20 AM
66fordf100
Dec 4, 2005 09:24 PM
fordman428
15
Dec 3, 2003 11:36 AM
tulsaokjoel
Aug 11, 2003 07:18 AM
