f150 knocking
Old Aug 17, 2013 | 04:30 AM
ivesbig's Avatar
ivesbig
f150 knocking
hey guys I have a 2008 fx4 with 75000 km it runs great but when I go on a long ride up hills or tow my trailer it acts up only when I get to my destination. the engine will run really rough and knock loudly seems only when I use reverse or sometimes park (and oil pressure in dash looks good),and if I shut ignition off and restart it no problems till I make engine work hard again.
Thanks in advance for reading this I appreciate any help
Old Aug 19, 2013 | 11:45 AM
70f100longbed's Avatar
70f100longbed
Ford has updated VCT solenoids for this problem. The part# is 8L3Z-6M280-B
Old Aug 19, 2013 | 03:10 PM
ivesbig's Avatar
ivesbig
Thank you for the reply long bed I will change that when I get home
Old Aug 21, 2013 | 08:38 PM
08F1Tizzy's Avatar
08F1Tizzy
Mine makes the same noise only while idling when the engines up to temp. How much do they go for and how hard are they to change?
Old Aug 21, 2013 | 09:38 PM
jeremy1's Avatar
jeremy1
I think they are about 65 bucks each and are easy to install. The driver side needs the intake plumbing and power steering reservoir moved out of the way. Pull off the connector, remove seal and one bolt. It has been a while since I have done one but they are easy.
Old Sep 3, 2013 | 06:28 PM
mrmurph's Avatar
mrmurph
On the 2008, do you have to remove the valve covers?
Old Sep 3, 2013 | 09:36 PM
jeremy1's Avatar
jeremy1
Nope. Unplug the wire pop out the rubber plastic boot and remove 1 screw. The VCT pulls out Careful not to tear the boot
Old Sep 4, 2013 | 12:47 AM
jfp3205's Avatar
jfp3205
what is the VCT and where is it? is it on a 2006 5.4
Old Sep 4, 2013 | 08:06 AM
jeremy1's Avatar
jeremy1
It is a solenoid valve that controls the flow of oil to the cam phaser position. This advances or retards your cam timing. It is located on the front of each head. You can see the passenger side one at the front of the valve cover. It has a plug about 1/12" inches in diameter with wires coming out
Old Sep 4, 2013 | 11:17 PM
Bwulf259's Avatar
Bwulf259
I had that problem on my 05 the VCT's didn't work so I run a thicker oil I put 15w-40 in it and it stopped it sounds stupid but it works
Old Sep 5, 2013 | 07:26 AM
jfp3205's Avatar
jfp3205
Would they throw codes if they are bad or should I go ahead and replace both since i have 135k on the motor to be safe
Old Sep 5, 2013 | 09:28 AM
jeremy1's Avatar
jeremy1
there is an updated version of these and it is recommended to change them if they have not been done already
Old Sep 5, 2013 | 09:55 AM
jfp3205's Avatar
jfp3205
where is the best place to get them from or is it a dealer only item
Old Sep 5, 2013 | 05:35 PM
jeremy1's Avatar
jeremy1
Dealer. You can try amazon or eBay. May find them for cheaper
Old Sep 13, 2013 | 02:22 PM
08F1Tizzy's Avatar
08F1Tizzy
I tried to remove the gasket and there's just no way I see too pop it out of the valve cover without destroying it. I'm gonna remove the valve covers.Are the valve cover gaskets reusable?
Frankm1103
May 23, 2018 08:13 PM
jkeduptrk
2004 - 2008 F150
Jan 8, 2017 02:59 PM
skipper_123
2004 - 2008 F150
Oct 15, 2013 06:53 PM
2000+1998
Sep 24, 2008 12:29 AM
GavinStevens
2004 - 2008 F150
16
Jun 30, 2006 03:16 PM
