Bed bolts
Old Aug 16, 2013 | 07:48 PM
FahrtAutoRC's Avatar
FahrtAutoRC
Bed bolts
'93 F-150 Stepside 4X4
HAS 3" BODY LIFT!
My goal here to eliminate the bed bouncing is to replace the bolts responsible, and since they are too rusted to be doing anything with other than grinding the heads off and knocking them through, replacement is my only option. Fine by me, will make the job quicker anyways!
My question is simple: Does anyone know the length and diameter I will need? I'm fairly certain about 9" long should do the trick but I have no way to tell or measure the diameter. I really only need the two on the right side in the middle and front, but I will likely go ahead and just get all six for good measure.
I do not need the "proper" bed bolts, and nothing rounded is necessary since I have a nice bedliner. Just standard bolts.
Also, what grade is best? Stainless steel preferable? I would only assume...
Eliminating this bed bounce will also allow me to listen easier and chase down the other rattles in this thing
Old Aug 16, 2013 | 07:56 PM
Bob Gervais's Avatar
Bob Gervais
They're 1/2 diameter. I used 5" galvanized carriage bolts, with no body lift.
Old Aug 16, 2013 | 08:00 PM
FahrtAutoRC
Awesome, thanks! So add another 3", plus another 1/2 to be safe, throw in some good lock washers, and done
Going to need a new grinder first though, my old one died on me, and the day I do the bed bolts I will be doing new rear spring shackles and hangars, too
Old Aug 16, 2013 | 09:25 PM
Bob Gervais
Good plan. I did hangers, shackles, frame scaling and paint, a 38 gallon fuel tank and a new fuel pump when I took my bed off.
backbeat
Jan 27, 2020 04:09 PM
diesel&coffee
Jul 22, 2013 10:41 AM
2radioactive4u
Sep 11, 2011 06:49 PM
1986fordrangerman
1997 - 2003 F150
Nov 28, 2008 09:21 PM
offroadguy
Mar 7, 2003 10:21 PM
