Sponsored by: Auxito
bed bolts
Old Nov 27, 2008 | 10:24 AM
1986fordrangerman's Avatar
1986fordrangerman
bed bolts
Does any know where you can find new bed bolts at or if you can even get them?
Old Nov 27, 2008 | 10:58 AM
DirtStripHero's Avatar
DirtStripHero
I would think the dealer could hook you up. But I would just go to the hardware store and pick up some new carriage bolts. They'll work fine.
Old Nov 28, 2008 | 10:56 AM
Ron W.'s Avatar
Ron W.
Get them from the dealer or contact one of the sponsers here. Hardware store will be a waste of time.
Old Nov 28, 2008 | 09:21 PM
1986fordrangerman
The reason I was asking this question is because whomever owned the truck before me looks like they tried to put a body lift kit on. However they only did the bed of the truck making it higher than the cab. I want to take out the spacer's that they put in there and return it to normal, only problem is the bolts are too long so I need to put shorter bolts back in. So would it be all right just to find some hardware store type bolts in or do I need to try and get the factory bolts? One other thing the does the bed set directly on the frame without any kind of rubber in between? Thanks
