steering column
Old Aug 22, 2013 | 02:56 PM
JEFFFAFA's Avatar
JEFFFAFA
As far as I know you will need a Rag Joint (Steering coupler) for the proberly equiped truck of the 77 column you are using. I.E. a/t,p/s,4x2,etc. Also you will have to do a little wiring work. You can use this Forum's search engine top of the page. I searched the "other" web site and picked up on adding a 78/79 tilt column. Here is a little wiring info.
According to the the '73 wiring diagrams:
  • red/black stripes to brake light switch
  • green/white stripes to LH front turn signal
  • white/orange stripes to emergency flasher
  • yellow/brown stripe (I could only find yellow/black stripe to LH rear turn signal)
  • white/blue stripe to RH front turn signal
  • blue to turn signal flasher
  • blue/red stripe to "PRNDL" lights (you wont need the wire to the "PRNDL" light since you have a manual shift.)
  • green to RH rear turn signal
  • yellow/blue to horn relay
Hobby welder
Oct 29, 2016 07:09 AM
DillyRay
May 22, 2014 03:00 PM
dj8667
May 4, 2005 10:16 PM
mechanicsburg
Nov 24, 2004 05:56 PM
robs68
20
Jul 17, 2000 04:41 PM
