What did I do wrong?
Old Aug 17, 2013 | 09:05 AM
x_man586's Avatar
x_man586
Sweet. I couldnt see all the way in the hole with a flashlight and mirror, and my little screw driver wasn't giving definitive answers either.
Old Aug 17, 2013 | 09:12 AM
x_man586's Avatar
x_man586
Now all I have to do is run power to the inertia swith, run fuel lines, install bypass regulator, fuel filter. Install choke cable, new throttle cable. Install carb, install dizzy... And more stuff.
Old Aug 17, 2013 | 10:03 AM
Gary Lewis's Avatar
Gary Lewis
Just for your edification, I cut up a good head just to show what you are dealing with.
The first shot shows the inside of the casting through the casting plug hole. The little hole stops in that blob of cast iron, but the big hole goes right on through via a drilled passage - all the way to the front, where it is usually plugged with an adapter that provides threads for accessories to mount on.
The second shot shows a cross-section of an exhaust port. You can see all the way through the hole that you plugged on the other end. And you can see how the air that was injected blended with the exhaust gases. Further, you can see how restricted the exhaust ports are on the smog Wheezer heads. The red shows where I ported to on another set of heads and got better exhaust flow.
Old Aug 17, 2013 | 11:29 AM
x_man586's Avatar
x_man586
awesome. I appreciate the education. I knew if I was willing to pull the engine I would be able to see what I am doing, but I am glad you are willing to post up this stuff.
Djkisling
1997 - 2003 F150
Feb 10, 2024 03:25 PM
DBGrif91
1997 - 2003 F150
Jan 14, 2024 08:50 PM
clem1226
Dec 29, 2013 07:02 PM
ArdB
Feb 26, 2010 03:45 PM
brewster1
Exhaust Systems
Aug 22, 2002 07:30 PM
