transmission help.
Old 08-12-2013, 08:57 PM
HotRodRob's Avatar
HotRodRob
HotRodRob is offline
transmission help.
hey guys, i got a 75 f150 with a 360 and a column shift 3 speed witch i am restoring, i ended up getting a 390 witch will be going in it, and i always wanted a 4 speed, what trans will just bolt up to my engine and into the truck with no problem, or should i just get a floor shift conversion for my 3 speed?
thanks
rob.
Old 08-12-2013, 09:12 PM
lafermedavid's Avatar
lafermedavid
lafermedavid is offline
manual tranny 4 speed granny
new process 435
Old 08-14-2013, 12:55 PM
HotRodRob's Avatar
HotRodRob
would a top loader 4 speed work? or a muncie? my dads got a muncie that i could use but i dont want to tear my truck apart for it not to work, thanks
Old 08-14-2013, 02:38 PM
jim collins's Avatar
jim collins
jim collins is offline
If you don't want a 4sp with the granny low gear then get the Ford top loader 4 sp, better than a GM muncie 4 sp. You can then remove the top cover plate, remove the shifting forks and shift rail. Plug the holes they went though and install a top mount shifter . You use one from a 76 to 79 Jeep CJ 7 . It's called a "T-176 '' , that Jeep used a top loader transmission provided by FORD. Modified for a 4x4 transfer and a different set of gears .
They used the 3sp top loader too. I bought a T-150 top shifter for a 3 sp top loader i have . I just picked it up last week and haven't made the conversion yet.
The Shifters are getting hard to get but i did see all of the parts to put together new one for the T-176 4sp.
Fhtagn
10-23-2016 02:19 PM
Sixoh
20
01-24-2016 05:52 PM
Bellot
12-11-2009 01:49 PM
jasontio2469
04-09-2006 03:12 PM
Warhorse86
01-31-2004 09:24 AM
Quick Reply: transmission help.
