As a brief intro I don't even qualify as a beginner mechanic. But, I live in a rural area, naturally curious, and willing to learn.
My 1991 F250 manual, 4x4 is a recent purchase (200,000km). Seemed to be in ok shape. Returning from a recent 140 km RT all of a sudden I lost power, but slowly. Full fuel tank. Gauges were good/checked fluids and let sit for a few minutes. Started up and went for a few more kilometers and the same experience. No power. Step 1: changed fuel filter on frame near front fuel tank. Good! Dirty. Worked fine for ~ 60 days. Then same problem. Took off the new fuel filter. Seemed clean and no debris.
1) Any first basic trouble shooting ideas?
2) Are there any other smaller/finer fuel filters closer to the engine?
Curious:
A) Looks like there is a separate gas line from each fuel tank; didn't see a junction; how does that work with only 1 single line fuel filter?
B) Following the gas line from the fuel filter to just below the engine, but still on the frame there is what looks like a 2 inch plastic square with the fuel line entering and exiting. Is this a sensor of some sort?
Russ
You need to check fuel pressure. It kind of sounds like you may have fuel pump issues. But I'm just guessing. You need to check fuel pressure.
Here is a website that might help. Fuel Injection Technical Library
How was the maintenance before you go it? Did they do tune-ups at the proper time? This sounds like a failing catalytic converter to me. It COULD be a fuel system issue as well, either a weak pump or bad electrical connection. Is it the same hot or cold?
My sense is the maintenance was performed regularly...it was the wife's truck. I intend to check the fuel pressure... Have, only experienced the condition after the truck has been operating for 20 min to 1 hour.
But your idea of "a failing catalytic converter" is also curious. Any basic ways to check that out?
A failing converter will not correct itself when the engine cools down. I would lean more towards the much more heat related failure attributed to the Ignition Control Module (ICM/TFI) mounted on the distributor or the stator (PIP) inside the distributor.
Then there is always the possibility of a failing fuel pump. The OP's 1991 should have high pressure pumps in each tank, so switching from one tank or the other should determine if it is a fuel pressure issue.
Pfogle looks like you were on the money. Seems the catalytic converter had corroded to the point of pieces...or so it was told to me. Does that make sense?
