Brake light switch
Old Aug 12, 2013 | 08:56 PM
truckpastor's Avatar
truckpastor
Brake light switch
Can someone tell me what colors the wires (are supposed to be) goes to brake light switch on master cylinder? Mine are missing from the switch connections.
Old Aug 13, 2013 | 04:53 AM
Col Flashman's Avatar
Col Flashman
Both of my original wires are Red.
Old Aug 13, 2013 | 08:15 AM
truckpastor
Thanks...I know it's weird but both wire connections are missing,but in the harness I notice someone spliced together a red w/blue stripe and a red wire together. And it doesn't look original .
Old Aug 13, 2013 | 07:10 PM
truckpastor
I think I figured it out...the PO for some strange reason thought it was easier to connect the two red wires that are supposed to snap on the switch instead of replacing switch with a new one...this would mean his brake lights were always on...don't get that one. The switch only cost 5 bucks
Old Aug 21, 2013 | 08:50 AM
saints2009's Avatar
saints2009
brake light switch replacement
When I change the switch, will I have to bleed the brakes?
Old Aug 21, 2013 | 07:55 PM
spurredon's Avatar
spurredon
Not if you are really fast! Welcome to FTE! You may have to just bleed a little air out around the new switch. Shouldn't get any air down in the line if you leave the pedal alone while you have the switch off.
By the way, I assume you are talking about a 57'-60' truck?, F100? It is always best to give plenty of info when asking questions.
Old Aug 22, 2013 | 07:40 PM
deyomatic's Avatar
deyomatic
It sounds like you're keeping it all original, so if you're using the original single master cylinder with the brake light switch in the end, then I didn't have to bleed anything when I replaced mine.
Old Aug 23, 2013 | 07:12 AM
truckpastor
I'm going to be replacing brake line anyways...so ill be borrowing someone with a strong leg
Old Aug 23, 2013 | 07:55 AM
hiball3985's Avatar
hiball3985
I'm running out of people to borrow so I broke down and bought a bleeder that pumps fluid from the wheel cylinder back into the master, works great. Are you replacing the hard lines or just the three rubber?
Old Aug 23, 2013 | 09:13 AM
deyomatic's Avatar
deyomatic
hiball,
Which bleeder did you buy? Phoenix? I've been using a vacuum bleeder for 3 days now and have finally come to the conclusion that my (second) master cylinder is junk right out of the box. It's been a week that makes me wish I had taken up golf.
hotrod12ga
15
Oct 13, 2021 03:09 AM
smangold
Jun 14, 2021 06:41 AM
hwyhogg
15
Dec 8, 2014 08:15 PM
Redmanbob
31
Feb 22, 2009 04:03 PM
tgowers
Nov 29, 2006 04:42 PM
