General Diesel Discussion
Need Help Identifying Engine
Old Aug 26, 2013 | 10:05 AM
VocaTexas's Avatar
VocaTexas
Originally Posted by 85e150six4mtod
That's a six, ain't it? I see six injector lines.
Yes, six cylinder with a Garrett turbo.
Old Aug 28, 2013 | 12:48 AM
Ford_Six's Avatar
Ford_Six
I don't think it's a Mercedes, those typically used an inline pump and the pushrod engines were a u-turn style rather than cross flow. Plus, Mercedes is proud of their stuff, throwing three pointed star on EVERYTHING.
It's not a Ford, it looks very similar to the Nissan SD33, but that is a u-turn as well. I haven't been able to find good pics of Hino or Mitsu engines of that era, but what I have found shows an inline pump. The pump is on the wrong side to be a Hercules.
So, pushrod engine, VE pump, and not a lot of things.
I'm going to venture a guess that it's Japanese though.
Old Sep 16, 2013 | 11:07 AM
lupuseven's Avatar
lupuseven
looks like time to do some serious cross referencing
take all part numbers you can find oil filter, alternator, ext
then get lists of all vehicles each part fits, and start crossing out the ones that arent on the list with all the other parts. you will probably be left with a 10 engine list but that will be easier the scanning the net for days not finding pics.
just my 2c
Old Sep 17, 2013 | 11:13 PM
Ford_Six's Avatar
Ford_Six
It's a Cummins 6AT. 3.4l, 120hp, generally pretty reliable. Not as common as the B series, but there are some people who have swapped them in. There's even a thread about it right here in the general diesel section.
Old Sep 18, 2013 | 01:13 AM
VocaTexas's Avatar
VocaTexas
THANK YOU, Ford Six! I think that's it!
What I think is the oil cooler is cracked on this engine and I need to fix it before I can use it next spring. Now that I have an idea of what it is, maybe I can find the part I need.
The folks on this forum are amazing sometimes!
Thanks again!
VegasFordSD
48
Jul 31, 2016 08:15 AM
asavage
Aerostar
26
Feb 8, 2008 04:05 PM
Reshel
Sep 30, 2006 08:32 AM
superchevy
1947 and Older Ford Trucks
16
Sep 6, 2006 02:17 AM
highboy390fe
Jan 25, 2006 06:20 PM
