C6 transmission gasket job
Old 08-12-2013, 05:51 PM
V10man's Avatar
V10man
V10man is offline
Do the converter too. Between dropping the pan and draining the converter you'll get about 90% of the fluid out. While you have the pan off lay it on a flat surface and see if any of the holes are distorted from over tightening. Use a hammer to tap the edge flat.
Old 08-12-2013, 06:27 PM
Corpsman24's Avatar
Corpsman24
Corpsman24 is offline
That makes sense, ya never know what superman has been wrenching on it in the past.
Old 08-12-2013, 10:14 PM
Corpsman24's Avatar
Corpsman24
In order to drop the tranny pan , I have to drop the skid plate. I see I need to remove 2 large bolts (each side) connecting skid plate by the rear of the trailing arms. Also the 2 bolts in skid plate (each side) at top of frame.
What about the 4 nuts right in the center of the skid plate, do they need to be removed ??? I am not sure what exactly they are connected to.... hhmmmm.
BillyBob69
08-12-2018 06:24 PM
tndiesel
11-18-2007 01:06 PM
BigGrizz76
02-04-2007 09:51 AM
Randolph
10-04-2006 10:05 AM
KevinW
02-16-2004 06:29 PM
Quick Reply: C6 transmission gasket job
