need help on c6 transmission line placement
Old 08-14-2013, 11:18 PM
DavidSmealII's Avatar
DavidSmealII
DavidSmealII is offline
Post need help on c6 transmission line placement
Alright. i need help with my 78 f250 with a c6 transmission. i've figured out which one is the inlet and out let on the transmission.
but i really need help on which one goes where on the radiator.
it also has a trans cooler on the core support.
As far as i know everything is like it is the way it comes from the factory i guess.
i tried putting it back the way it was before when i took it off 4 months ago (memory is fuzzy on how it all went together) but its not going like i figure.
i just needs some input on how it flows from the trans. then to cooler, to the radiator, then back to the trans again
Old 08-14-2013, 11:36 PM
myoldfords's Avatar
myoldfords
myoldfords is offline
I goes from the trans, to the radiator, then the cooler. It doesn't matter which direction it flows through the radiator and cooler as long as it goes in the right order.
Old 08-14-2013, 11:43 PM
DavidSmealII
alright thank you! wasnt sure if it mattered to the flow or not
jaleus
11-18-2022 12:01 AM
56exp
06-30-2019 12:52 PM
lud04X
08-15-2016 09:21 AM
Drac
11-23-2011 11:39 AM
Franko72
08-11-2010 05:12 PM
Quick Reply: need help on c6 transmission line placement
