1970 Antenna
Old Aug 11, 2013 | 07:15 PM
Neschenbrenner001's Avatar
Neschenbrenner001
1970 Antenna
Hello everyone,
I'm new and I have a question I'm trying to find out what the best way is to fish an antenna wire threw the firewall of my truck a 1970 f100. I just got this truck a week ago and it had no antenna I have a new one I just cant seem to get the wire threw the holes any help would be great.
Thanks
Old Aug 11, 2013 | 09:52 PM
HIO Silver's Avatar
HIO Silver
It's really difficult to push a rope so you're gonna have to go fishing.
Undo a wire coat hanger and fashion a short hook on the end. Insert and dangle the antenna lead through the cowl and then use the coat hanger to hook and draw it into the cab.
You can do it.
Old Aug 12, 2013 | 10:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There's more than one way to 'skin a cat.'
Unplug antenna lead wire from radio, tie a long piece of twine to it. Remove antenna from cowl panel.
Tie twine to new antenna lead wire, pull twine from inside cab, lead wire will easily feed thru hole in cowl panel.
Feeding new lead wire thru hole in cowl panel without twine or coat hanger method is a PITA!
Old Aug 12, 2013 | 11:21 AM
HIO Silver's Avatar
HIO Silver
^^^ RTFP... impossible to do without an antenna to remove.
Old Aug 12, 2013 | 12:59 PM
Neschenbrenner001
There is no antenna there right now just a hole the old wire is inside the cab. I tried last night for about a hour till i got frustrated. No luck. I will try again tomorrow and let you guys know how it goes.
Austin Burden
Apr 7, 2019 03:09 PM
Riderman
Feb 13, 2015 06:20 PM
RednecksF150
28
Jan 18, 2011 10:41 PM
kilog55
Apr 18, 2007 01:38 PM
