Just got off the highway from a 3 hour trip. Had the vents on. Now when I went to turn off the vents. My A/C automatically goes to defrost. I cannot turn off the fan. I turn the auto climate control. All's as it should be but cannot turn off the A/C when I push the off button. Going out to look at the truck now.
Do you electronic 4-wheel drive? Sounds like it. One side prob has a leak at the inside of the wheel.....It's a hose from the vacuum pump located on pass side fender.
Yes I have the ESOF. My 4X4 is working correctly. Because if the A/C is on and I switch the 4X4 on my A/C still working through the front vents and not through the front defrost. I was out for a drive and fond that it's not the A/C I cannot turn of but it's my blower motor. It seems to be stuck in the high speed. I cannot even turn the speed down to minimum.
Hope it's something simple.
Does anyone know what fuse to pull just till I get home next week and start diagnosing?
After reading some old posts I think it might be the "Blower motor speed controller". Think it is located under the hood on the right side firewall/fender area. Could any confirm this or supply a good picture of this part?
What about disabling it till I get home. Anyone know off hand the fuse to pull?
Yup, these symptoms are typical of a failing resistor. The symptoms will surely come back. I had the same symptoms and ended up replacing the resistor, no more issues. Matter of time, known problem.
Heres a couple of pics of mine showing location and replacement.
