charging problem
Old Aug 10, 2013 | 08:02 PM
JpDrvinMyLfAwy's Avatar
JpDrvinMyLfAwy
charging problem
So my truck stopped charging today. After going through the steps, I find out that the alternator is not getting the keyed power source . Any one have any ideas? Thanks
Oh and is a 93 150
Old Aug 10, 2013 | 08:09 PM
Encho's Avatar
Encho
The Southernmost Mod
Yep, check the brushes for wear, if that isn't the cause then replace the regulator. Of course, before all this check all the wiring related to the alternator for corrosion or loose ends.
Old Aug 11, 2013 | 11:45 AM
rla2005's Avatar
rla2005
The Green/Red "exciter" voltage wire is fed through the ignition switch to the instrument cluster then onto the alternator. Some have found a simple open bulb will prevent voltage from making it to the alternator. There is supposed to be a shunt resistor, but I have seen a few of those to fail too.
Here is a basic diagram from oldfuelinjection.com:
sgauvry
24
Apr 7, 2017 03:36 PM
stevenjf88
17
Dec 3, 2015 04:50 PM
ktz78
Dec 20, 2010 11:10 PM
51dueller
Jul 24, 2004 06:34 AM
rfgree
Mar 2, 2003 12:56 AM
