help just rebuilt 351w
Old Aug 10, 2013 | 07:32 PM
Rayrider911's Avatar
Rayrider911
Question help just rebuilt 351w
hey guys just need some input rebuilt 94 f150 351w bored 40 rhs heads comp 262h cam just got it running with stock ecm runs rough but idles wont idle in drive though do yall think its the map ecm, im planning on taking it to the dyno get a chip burned for it at speedtek or have em replace it with the maf computer i got at the wrecking yard off a 94 f150. also the oil pressure gauge has never worked on this truck and i replaced the sensor and still doesnt work i primed it with a drill and it worked fine do yall think its just the wiring maybe or what do i look for if its a bad pump?
Old Aug 10, 2013 | 09:25 PM
Conanski's Avatar
Conanski
That cam is not compatible with the stock PCM in that truck so you need MAF and a tune.
Old Aug 11, 2013 | 09:07 AM
Rayrider911
that's the plan but i have to wait two weeks before its scheduled at the dyno for the computer swap and tune just making sure that the computer is the problem and not something like over tightened valves.
Old Aug 11, 2013 | 09:22 AM
Conanski's Avatar
Conanski
Do you have larger injectors in it?
You are aware a MAF conversion is more than just a computer swap there are wiring harness additions as well.
Old Aug 11, 2013 | 10:49 AM
Evan_P's Avatar
Evan_P
MAF sensor, wiring for said sensor, all new intake system to use said sensor, sequential injector harness, and EEC swap. All of which require the EEC connector to be re-pinned. Lot more than swapping the computer out. If only it were that easy...
Old Aug 11, 2013 | 05:13 PM
Rayrider911
Ya I Got all the stuff off the donor truck all wires sensors computer everything I need for the swap gonna let the guys at the shop swap it out and tune it just to be sure I don't screw up my brand new engine.
JRS2
May 11, 2015 07:02 PM
Hickfied
Jul 24, 2013 07:25 PM
Gregallen
Feb 7, 2011 07:38 AM
wozxxx86
1978 - 1996 Big Bronco
Aug 23, 2004 10:01 PM
bluoval
Feb 9, 2002 10:20 PM
