1964 F100
Old Aug 10, 2013 | 02:39 PM
Madrid1214's Avatar
Madrid1214
1964 F100
Hello. I just recently bought my first vehicle, a 1964 Ford F100 long bed with a 292 in it. 3speed custom cab.
Been having some trouble regarding parts. I checked out Autozone/NAPA/O'Reilly to buy a water pump and some gaskets but every time they check, they don't have any parts listed for the V8, only V6.
Is the water pump different from V8 and V6? I purchased a thermal stat and accidentally said it was a V6 and the when I got home, the one I took off is way different from the V8.
Thanks so much for the replies. You guys will be hearing a lot from me.
Old Aug 10, 2013 | 02:55 PM
Mattrod68's Avatar
Mattrod68
got these off of the hamb, y block water pump, try these
"New water pump $79 bones from Napa item# NWP55488
reman $37.89 with core of $11.11 item # WP58200"
Old Aug 10, 2013 | 03:31 PM
Madrid1214's Avatar
Madrid1214
I went to NAPAs website and typed it in but once i select the V8, there is no pump. I also try that item number but nothing. It's only for the V6. I even called a local NAPA and they only have the V6 water pump. Thanks, Mattrod68.
Old Aug 10, 2013 | 05:07 PM
Elgringo64's Avatar
Elgringo64
parts plus
I also have a 1964 F100 longbed and has a 302 with 4 on floor(not stock),did have a 292 in it org. check at a merles or parts plus they have always seemed to have every thing I needed.
Old Aug 10, 2013 | 06:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Madrid1214
Hello. I just recently bought my first vehicle, a 1964 Ford F100 long bed with a 292 in it. 3speed custom cab. Been having some trouble regarding parts.
Welcome to FTE
"Who goofed? I've got to know!" -Howard Cosell on MNF
No such thing as a V6 installed in any truck prior to 1982. 1982/83 were the only years that a V6 (3.8L) was available (and only in F100's) until 1997.
1964 F100 available engines: 223 1V Inline 6 - 262 1V Inline 6 / 292 2V Y block V8.
The problem is: Chain autoparts stores usually do not have older parts listed on their 'puters. You have to get the parts clucks to look in their paper parts catalogs, usually stashed under the counter.
B6C-8501-B .. Waterpump ~ 1956/64 F100/700 292 / Obsolete ~ 4 available NOS
Old Aug 10, 2013 | 07:18 PM
arctic y block's Avatar
arctic y block
A V6 in a 64, Now that's funny.
Use the part number that Bill just gave ya.
Take it to Napa and get one prolly off the shelf.
Old Aug 11, 2013 | 09:29 AM
Madrid1214's Avatar
Madrid1214
NumberDummy and arctic y block; Sorry about the V6 thing. Not too experience about vehicles and whatnot. But you knew what I meant. :-) Thank you for the info. This is helpful.
I had two more questions. I need another rear differential since the original owner switched it out for a more heavier duty one, it has 8 lug nuts rather than 5. To what year what a rear differential fit a 64?
Second question, I'm planning to make it a short bed, what size drive shaft will I need for the conversion? AND Where is the best place to cut?
I thank you all for the contribution and sorry for the bombardment of questions. I'm just really excited about the project. Thank you again.
Old Aug 11, 2013 | 09:42 AM
NumberDummy
F250's came with Dana 60's that use 8 lug wheels on a 6.50" bolt circle.
1961/72 F100 9" rear axle will interchange, but 1968/72's have larger rear brakes: 11" x 2 1/4" vs 11" x 1 3/4."
But, not all 1961/67's, some 1968's will have a 9" because if Limited Slip was ordered, Ford installed Dana 44 rear axles that have an inspection cover (like the 60), the 9 does not.
PepFord
Feb 15, 2019 08:17 PM
MichiganLarry
Nov 10, 2015 02:54 PM
waltharper
Oregon Chapter
Dec 3, 2014 12:53 AM
tsl_man
Jul 22, 2008 09:14 AM
19F10059
Jan 13, 2002 08:23 PM
