need help
Old Aug 9, 2013 | 04:16 AM
robbiebrown25's Avatar
robbiebrown25
need help
replaced a the exhaust gasket and manifold gasket while doing that I broke the egr line if it broke will it cause the truck to go crazy and idle about 5000 rmps when it starts
Old Aug 9, 2013 | 09:35 AM
Conanski's Avatar
Conanski
No it shouldn't unless there is a problem with EGR valve. But even if everything is working correctly you still need to block of both ends of the EGR system to prevent fresh air getting into the exhaust or getting drawn into the engine where it will mess with the A/F ratio and make the motor run bad. I suggest installing a piece of sheet metal between the valve and intake and plug the exhaust manifold with whatever you can get your hands that will seal 100%.
N1265
Apr 21, 2018 08:12 AM
Tasteslikeink
1997 - 2003 F150
24
Mar 25, 2014 06:08 PM
jishieldsjr
Sep 22, 2009 10:43 AM
Oregon86_F250
Mar 7, 2006 12:23 PM
forddytube
Jan 5, 2003 12:40 AM
