96 w/ 302 engine stats
Old Aug 8, 2013 | 05:40 PM
khakushia's Avatar
khakushia
So my truck runs like crap. Been running like crap for a while. But that is neither here nor there. Done the tune up and ect. I have a real nice odb2 scanner that tells me what the engine is doing. Timing, rpm, speed, 02 sensor, o2 sensor 2 ect. Does anyone have a list of roughly what the stats would be for a "stock engine" I just want to see if everything is in line or if there is something thats off.
Old Aug 8, 2013 | 10:10 PM
MeanGreen460's Avatar
MeanGreen460
You said you tuned it up.What parts did you replace?Plugs ;cap rotor plug wires fuel air filters pvc valve .No trouble codes?
Old Aug 9, 2013 | 10:35 AM
khakushia's Avatar
khakushia
correct all the typical stuff, plugs, wires, cold air intake, ect. the basics
Old Aug 9, 2013 | 10:59 AM
khakushia's Avatar
khakushia
I been having this problem for a while. I asked questions in the past. I tinker with it here and there but its still just not "right"
Old Aug 9, 2013 | 01:20 PM
Conanski's Avatar
Conanski
Have you pulled the codes recently?
Are you 100% sure the plug wires were re-installed with the correct firing order?
Old Aug 9, 2013 | 03:48 PM
kermmydog's Avatar
kermmydog
If you have a real nice OBD II scanner why won't it give you the codes, to help you fix the problem????
Only time I have seen a NO CODE running bad is fuel pumps & filters. Other than maybe a lean code.
Craig
Old Aug 9, 2013 | 05:08 PM
Encho's Avatar
Encho
The Southernmost Mod
Have you checked for vacuum or exhaust leaks?.
Old Aug 9, 2013 | 08:04 PM
khakushia's Avatar
khakushia
checked for vacuum leak. All bases are covered. No exhaust leak. I checked the fuel pressure today because i was able to convince myself that was the problem. wrong. Fuel pressure was in spec for engine on and engine off. Didnt drop while engine was off. Have no codes. The only time it throws a code is because a vac line becomes loose. I am lost for words. I am ready to rip out the engine and do an over haul if it wasnt for the fact i have no where to work on it at.
Sailor_963
Apr 9, 2016 07:36 PM
FordYoungGun35
Oct 31, 2013 01:22 PM
llljllollnlll
Dec 12, 2012 11:33 PM
ryantremblay
1983 - 2012 Ranger & B-Series
Jul 5, 2005 08:49 AM
79F350429
Feb 1, 2005 10:26 PM
