transmission fluid change
Old Aug 8, 2013 | 11:03 AM
1992FordF150Custom's Avatar
1992FordF150Custom
i have a 1992 f150 with a 5-speed M5OD and i'm going to change tranny fluid but what fluid does it take, and how much?
Old Aug 8, 2013 | 01:54 PM
Encho's Avatar
Encho
The Southernmost Mod
It takes Mercon ATF, and it takes 5qts. but don't quote me on the capacity, I'll check my OM and will confirm this later.
Old Aug 8, 2013 | 07:57 PM
MeanGreen460's Avatar
MeanGreen460
Mercon 5 ATF fill it up totop of hole or so you can touch it with the end of your finger
Old Aug 8, 2013 | 08:35 PM
Encho's Avatar
Encho
Mercon V ATF wasn't available when these trucks rolled out of the assembly line, but it is supposed to work everywhere Mercon ATF was used, just don't mix both products.
Old Aug 8, 2013 | 11:14 PM
1992FordF150Custom
i put some valoline maxlife high milage ATF in it, and my truck shifts abit smoother but when i down shift from 3rd to 2nd it grinds, it did this before but i hoped new fluid would make it better, double clutching doesn't help, whats this sound like?
Old Aug 8, 2013 | 11:20 PM
88LX5.0H's Avatar
88LX5.0H
Worn syncro
Old Aug 8, 2013 | 11:40 PM
1992FordF150Custom
could i just get a syncro or would i need to find a tranny?
Old Aug 9, 2013 | 04:47 AM
Pellas's Avatar
Pellas
Well, would you look at that, a manual that takes ATF.
Seems right, just a bit unusual.
Yes you can definetly get new syncros, but you'll have to have the whole gearbox apart, do some googleing on walktroughs, and if you're unsure i'd have a workshop do it.
And by then it's probably cheaper to get another second-hand unit. But then you never know what sort of nick that'd be in either.....
Old Aug 9, 2013 | 05:11 AM
rla2005's Avatar
rla2005
My OM shows the Mazda M5 manual transmission takes 3.8 quarts of Mercon automatic transmission fluid. The ZF takes 3.4 quarts of the same.
Old Aug 9, 2013 | 09:23 PM
88LX5.0H's Avatar
88LX5.0H
Seems right, just a bit unusual.)
Not unusual at all. Extremely common, really.
Charles Lipari
Mar 28, 2017 07:52 PM
85F350IDI
19
Jul 11, 2015 11:02 AM
BAD RONALD
Jun 10, 2013 09:48 PM
Spyderrc10gt2
Sep 30, 2005 05:47 PM
ford390gashog
Oil & Lubrication
Jan 11, 2005 08:19 AM
