'80-86 Bullnose For Four Wheeler Feature Truck
I do the "Backwards Glances" 4x4 column for Four Wheeler Magazine and I'm not getting enough vintage Fords in there. I'm looking for an original-and-unmolested, restored-to-stock or near-to-stock '80-86 4x4 truck. Yes, I have one, and yes it's been a camera ***** many times so I'm looking for some "strange." If you have such a truck, or know of someone who does, please get back with me here or via PM. The hitch will be location. I'm in NW Ohio and the truck needs to be within a reasonable driving distance from there. Say a day's travel time, which would include most of Indiana, some of Illinois, Northern Kentucky, most of Michigan, Western PA, West Virginia and possibly farther away depending on the truck. I am so woefully short of vintage Ford pickup stuff that if there was a collector that had other era 4x4 Ford trucks in original condition ('59-60, '61-66, '67-73, '74-79) that filled the bill, I go father to shoot a bunch-o-Ford-trucks. Here's your chance to be immortalized in print and on the internet. Thanks Gents!
If you want to see the kind of stuff that's been done so far, here's a link to a search: Google
How "restored-to-stock or near-to-stock" does it have to be? And, is this a one-time offer? I'm currently restifying my father's 1981 F150 4x4, and plan to have it at the Carlisle All-Ford meet at the end of May/start of June next summer. Dad is '93 and loved the truck, but he has Alzheimer's and doesn't remember it and I've taken possession. I'm sorta restoring it, but the way I want it. Here's a bit of info on it, but you can find more than you would ever want to know about it in the thread called Dad's Truck Build:
- 1981 F140 4x4 Ranger XLT
- Originally a 351M, but it is getting stroked by 1/2", which makes it a 400, along with a few other things like Edelbrock heads, intake, and some reasonable cam.
- Originally had a C6, but I now have a ZF5 in it - or will have again when it goes back together. And, by the way, ZF's will bolt up to a 351M, but won't work w/o a bit of effort. See Dad's ZF5 Swap for the details of how I did it.
- The seat is being changed out with period-correct Bronco buckets and console, with factory-like fabric
- Radio will be changed to a RetroSoundsUSA unit that will look correct but has Bluetooth, hands-free, etc. Speakers will be upgraded but in stock locations except for the sub, which will be a small one under the passenger's seat.
- Stock Ford aluminum bullet-hole wheels and slightly-upgraded tires
- The engine compartment will look stock, but there will be a few upgrades that only the knowledgable will catch, like the 351HO air cleaner with dual snorkels and cold air ducting, 3G alternator, headlight wiring harness, etc
- Concealed alarm system connected to the power door locks.
- Speaking of door locks, it will have the pin-style locks and door panels instead of the slide locks the 80 & 81's had.
- Cargo light upgraded to a later Ford cargo/brake light
- Paint/bodywork - much better than factory, including a clear coat, but original color.
The Backwards Glances column is all about originality. The basic core of the idea is to give folks a look back... the way it was. A few small mods here or there are OK but nothing that changes the basic look or functionality. I know there are some great restified trucks out there and some that are full blown modified. And I love 'em! But that's not what the column is about.
I've own my Bullnose almost since it was new and made some changes. Now that it's more or less a toy, ...all those things I changed back in the day are getting changed back to stock. Wish I'd saved all the stuff I took out!
I understand the need for originality due to the name and intent of the column. And, I understand the problem of finding original trucks since these trucks were problematic in many areas. Take the emissions equipment as an example - it is difficult to maintain and few know how to do it, so it is frequently removed. And, several of the engines of the day were out and out dogs - take the 351M for example. I own a stock one that is truly gutless and thirsty. And, I own a "built" one that has spunk and gets almost 50% better MPG. Then there are transmissions - our trucks either came with autos that had no OD or one that was fairly weak, and the only manual transmissions with OD were also fairly weak.
So, it is very easy to see why there are so few truly original trucks of this era available any more. Earlier trucks didn't have the "stuff" on them to go wrong, and later trucks had "stuff" that works better and can be maintained. Unfortunately, our era is at the bottom of the curve, so to speak. So good luck with your quest, it must be frustrating.
Jim Allen
16
08-14-2013 12:45 PM
Jim Allen
08-08-2013 03:57 PM
