'92 E4OD ticking noise
Old Aug 6, 2013 | 09:32 PM
stephen.osborne1's Avatar
stephen.osborne1
I recently replaced the seals in the front pump of my daughter's '92 f-150 SCAB, 302 4x4 with the E4OD. Since putting the trans all back in and together, it now makes a nasty ticking noise. It is mostly noticeable in park and idle, but you hear it as RPMs increase in gear. It is definitely coming from the front of the trans. I pulled the inspection plate today, thinking it may be a cracked flex plate, but saw no cracks. Would a torque converter make a ticking or clicking noise if it were going bad? Other than the noise, the truck runs and shifts fine with 212,xxx on it (Though I do believe that the PO replaced the trans at one time). Any other ideas?
MR KROGOTH
16
Feb 9, 2020 06:14 PM
Donald Taylor
May 1, 2016 09:57 AM
stephen.osborne1
Aug 18, 2013 07:55 AM
Matt In Detroit
Feb 17, 2009 03:15 AM
