Fuel Pressure Regulator?
Old Aug 6, 2013 | 07:30 PM
muleyhunter's Avatar
muleyhunter
Hey all i have this truck a '92 with a 5.0L. Currently i am getting bad mileage and sputtering. I hooked the fuel pressure tester up and at KOEO it goes to 40 psi then drops to zero within 10 or so seconds. With the engine running at idle the fuel pressure is at 70psi. My research points me to the fuel pressure regulator, just want to double check if someone has seen this as well before i pull those annoying screws out. Thanks.
Old Aug 6, 2013 | 07:40 PM
kermmydog's Avatar
kermmydog
Fuel Injection Technical Library » Fuel Pressure Regulator (FPR)
Here is a link that might help you.
Craig
Old Aug 6, 2013 | 07:51 PM
Conanski's Avatar
Conanski
70psi is way too high so something is definitely wrong but it might not be just the regulator. Are any of the plugs wet? Do you have the fuel transfer problem?
Old Aug 7, 2013 | 10:32 AM
muleyhunter
Changed that pain in the *** regulator, pressures are now in spec., truck running great. Thanks for the advice.
Old Aug 7, 2013 | 12:15 PM
kermmydog's Avatar
kermmydog
Glad you got it fixed.
Craig
1989 4x4
Nov 6, 2018 06:24 AM
broncoII89
Bronco II
May 31, 2005 07:54 PM
300inline6
May 16, 2004 05:37 PM
hbbowlvt
Modular V8 (4.6L, 5.4L)
Feb 12, 2004 08:54 AM
