way to rich
Old Aug 6, 2013 | 04:03 PM
the Canadian's Avatar
the Canadian
way to rich
can somebody give me some advice, I have a 302 in my truck with a mild performer cam e- street heads small valves performer dual plane intake headers. My 4105 600 cfm manual choke carb is way to rich I have checked the floats they are at 7/16 just like the manual says. Its mostly when idling and very hard to start and when it does lots of black smoke. could a 600 cfm be to big for a 302. O ya I am running 5lbs fuel pressure. Need help.
Old Aug 6, 2013 | 05:16 PM
JEFFFAFA's Avatar
JEFFFAFA
A 600 should be fine for the way you set up that 302. The problem is eddy's are set up rich at the factory. Aimed at more cubic inches than your 302. Try primary (front) metering rods 2 sizes leaner.
Old Aug 7, 2013 | 08:01 AM
the Canadian
Thanks for the advice. but when it comes to carbs I no nothing the two rods are out now and they have orange springs but I don't know the size of the rods. the carb right now is stock. So could you dumb it down for me thanks.
Old Aug 7, 2013 | 08:16 AM
Alex from GA's Avatar
Alex from GA
IMO you have to measure the fuel mixture % to tune correctly. The days of "lean it down 10 and run it" have past.
Old Aug 7, 2013 | 10:33 AM
Area351's Avatar
Area351
It's "too" not "to".....
Old Aug 7, 2013 | 10:52 AM
JEFFFAFA's Avatar
JEFFFAFA
Here is stock calibration metering rods and their jets.
REF # MAIN JET METERING ROD CHANGE FROM BASE
1....................1428 (.100") .......................... 1451 (.070" x .047")*..............................none - stock calibration
Here is what I suggest. Part number 1459 metering rods. Please let me know how it turns out.
25....................1428 (.100")............................1459 (.075" x .047") ..............................R
Old Aug 7, 2013 | 10:55 AM
JEFFFAFA's Avatar
JEFFFAFA
Two steps is 8% leaner.
Old Aug 7, 2013 | 11:48 AM
Alex from GA
This was in the days before electronics and quadrajet carburetors. The number 10 means jet sizes not percentages.
Old Aug 14, 2013 | 08:01 AM
the Canadian
Thanks for the help. I was away for a week. I am going to try your advice this weekend. I will let you know how things go.
Old Aug 14, 2013 | 02:03 PM
Freightrain's Avatar
Freightrain
I have a Carter "Strip kit" from 20 odd years ago. Seems all the metering rods had numbers stamped on them for easy reference. I used to play around with that style carb many years ago. I've since changed to Holley and never looked back.
effie1
Dec 2, 2009 10:57 AM
LARIAT 85
Jan 4, 2007 11:57 AM
ClatonK
Jan 9, 2005 02:12 PM
mooseknuckle
1966 - 1977 Early Broncos
Mar 3, 2004 04:17 AM
69BRONCO
May 25, 2002 10:14 PM
