Auxiliary relay issues
My point was good crimp or good soldered will work. Poor technique on either is bad.
That said, NASA, among others, actually prefers crimped.
"Crimping is an efficient and highly reliable method to assemble and terminate conductors, and typically provides a stronger, more reliable termination method than that achieved by soldering."
The guy saying crimping = bad is just bull.
and using these type of connectors (I got these from NAPA) they're fail safe especially when I solder over them.
This was how I rewired parts of my PDB for 12 gauge.
.I charged the truck for the night with the maintainer and when I started it up in the morning everything came on and seemed to work well...until I hit a railway crossing and the accessories shut off...then came back on again when I hit a pothole and that was it for blips for the day. Today I've had multiple on and off's again, with a few occurrences of my windshield wipers activating...sort of...without the switch being on. They would go up, stop, and then make their way back down in a jerky motion like the motor is being pulsed.
I'm not sure where to look, whether I've go a short somewhere, the connections for the relay in the panel are bad, there's another relay that's malfunctioning of if it's a power problem?
My batteries are just over 2 year old Exide Sub Zeros (1,000ca 850cca) & my Edge is showing me voltage of 13.2-13.8. I have also just added a Noco Genius G3500 smart charger which I've mounted under the hood.
Perhaps Ford expected the cover to hold the relays down into their sockets but I think they would have better engineering than that.
My first step would probably be to turn on the things that are dying and wiggle the relays from the side (so you're not pushing them in) to see if you find the offending one. If you can get to them maybe even inserting something plastic between the relay and the base to see if any are really easy to break the circuit on, simulate over the road jostling as it were.
ps. sorry about the hijack.
