1992 4x4 trans question
Old Aug 5, 2013 | 10:08 PM
dpty22's Avatar
dpty22
I have a 1992 f150 4x4 with a 4.9 and a 4 speed manual trans. I have come across a 1992 f150 4x4 with a 4.9 and a 5 speed manual trans. Aside from all the other parts that will swap, am I going to run into any problems swapping the transmission and transfercase to the 5 speed. Is the clutch configuration the same between the 4 speed and 5 speed.
Old Aug 6, 2013 | 06:21 AM
tjc transport's Avatar
tjc transport
i ain't rite
the 4 speed you have in there now was swapped in, after 88 the manual trans was a 5 speed.
last year for a 4 speed manual trans was 87.
Old Aug 6, 2013 | 11:55 AM
quaddriver's Avatar
quaddriver
Im inclined to agree 100% with the first response, but temper with: ford builds a lot of stuff for our southern and northern neighbors and if the deal does not go thru then stuff not on the dealer sheets for the US shows up.
just outta curiosity, what 4sdpd is in there? got any parts numbers or the like?
Old Aug 6, 2013 | 12:30 PM
dpty22's Avatar
dpty22
I don't have numbers for it but research suggests, that may be a T-18. The truck started life as a fleet vehicle for the US forestry service. It is such a low geared set up. 60 mph is about as fast as you want to drive it. That is the reason for the 5 speed swap.
obscurity
Jul 2, 2013 09:52 AM
dventoza
Jan 9, 2011 10:24 PM
Roger T. Pipe
Oct 22, 2009 01:23 AM
86halfton
Jan 10, 2009 12:22 PM
bcam69
Jan 20, 2008 10:25 PM
