Vss
Old Jan 23, 2006 | 02:59 PM
zcarguy's Avatar
zcarguy
Vss
OK, I have searched this forum about the Vehicle Speed Sensor and have read almost all of the topics, which is many, and I am still confused.
I have a 1992 4x2 F-150 300ci M5OD. The speedo/odo/cruise occasionly drops dead, then comes back to life after about 10 minutes. I think that it is safe to say that the VSS is the problem.
I went to ALL of the parts stores in town and they all want to sell me the VSS that is the long skinny one which obviously attaches to a speedo cable. The problems with this are 1) My truck doesn't have a speedo cable 2) I have taken mulitple passes of the entire drive train on my creeper and can not find anything that even resembles this part.
The only 2 eletrical connections I see are the reverse light switch and the sensor on the diff, which all of the parts stores (including the Ford dealship) say is the ABS sensor.
Is it possible that this "ABS sensor" also doubles as the VSS on my truck? Is the so-called ABS sensor actually the VSS?
Old Jan 23, 2006 | 03:24 PM
quicklook2's Avatar
quicklook2
sensor on differential is for abs and for vehicle speed.
Old Jan 23, 2006 | 03:31 PM
andym's Avatar
andym
Yes, from 1992 up the VSS and the ABS sensor are exactly the same part.
Because of the intermittent nature of your problem, I would suspect a wiring problem before I thought the VSS or speedo head was bad. I'd get under there and check the wiring real good before spending any money on parts.
Old Jan 23, 2006 | 04:29 PM
zcarguy's Avatar
zcarguy
Thanks for the info.... I had originally purchased the "other part" and while disassembling it, only to find out it was the wrong part, I snapped off one of the ears of the eletrical connection. It has been an on-going problem that has become more frequent. The $30 for the sensor and the connector it would be worthwile to do both while I'm down there. If the problem still persists I can look into other things.
