393 efi build?
Old Aug 5, 2013 | 09:32 AM
f150inline's Avatar
f150inline
393 efi build?
The straight six in my truck isn't really cutting it power wise for me and I plan to buy a complete 351 out of a 95 bronco, put in a scat 3.850 crank, stock 351 rods, 302 .30 pistons, gt40 heads, stock truck intake, and a custom grind from compcams. I am shooting for like 9.5-10-1 compression, 350+ft lbs at low rpm and be able to pass emmissions in pa. If anyone has any advice on how to achieve this let me know.
Old Aug 5, 2013 | 11:45 AM
Conanski's Avatar
Conanski
Your aiming WAAAAY too low.. if you put that 351 in just as it is with longtube headers on it you'll exceed those torque goals and a 393 is gonna make 100ft/lbs more than that. The problem you're gonna have is making a stroker run on the stock truck EFI system, fueling requirements are gonna be higher at all rpms so you're gonna need MAF for sure and if your truck has a computer controlled auto that limits PCM choices.
Here's a dyno sim for a 5.8 with stock cam and 1.7 rockers, GT40 heads and longtubes and a 393 with the same. The 5.8 has about 9:1 compression with those heads while the 393 is a touch under 10:1..9.89 to be exact. With the stock truck intake on these motors you won't get the horsepower shown.. both combos will run into a wall at 3500-4000rpm so don't expect more than 250-260hp, but low rpm torque should be even higher.
Old Aug 5, 2013 | 01:40 PM
85e150's Avatar
85e150
Better check those PA smog regs. Hasn't PA adopted the CA standards? If so, you be hard pressed to pass with that set up. I didn't go all the way through their site, as it was a new vehicle purchase question.
Links are in this thread:
https://www.ford-trucks.com/forums/1...l#post13399531
Old Aug 5, 2013 | 02:30 PM
f150inline's Avatar
f150inline
Those only apply to 2008 and up vehicles.
Old Aug 5, 2013 | 02:34 PM
f150inline's Avatar
f150inline
The truck has a m5od, which will be replaced by a zf5 before the swap or after the m5od blows up.
I definitely plan on maf.
I am building this for a wheeler so lots of low end torque is good, but the truck is also my daily driver so I like to have a little power at the higher end, since I am a typical 16 year old kid and I like to stomp it from time to time.
Old Aug 5, 2013 | 05:05 PM
85e150's Avatar
85e150
Better read further. What county are you in?
PA DEP I/M - Emission Test Calculator
Old Aug 6, 2013 | 05:14 PM
Kemicalburns's Avatar
Kemicalburns
since your driving a 96 f150, locate same year truck out of a wrecking yard with either a 5.0 or 5.8 and grab the motor and entire wiring harness/sensors/computer and swap over to your truck.
Bayer-Z28
15
Jan 20, 2020 07:47 PM
abninf87
Sep 21, 2009 10:17 PM
Bossman89
Nov 1, 2006 06:35 PM
Tripower455
26
Oct 2, 2005 04:48 PM
rhetor
13
Jul 8, 2005 10:28 AM
