High fuel pressure
https://www.ford-trucks.com/forums/1...he-forums.html
Sean :-dirnk
Well it appears that I have done it! Thanks Sean! You can see from this pic that the new one is larger, and appears to live up to the claim of being "more heavy duty". It seems to be working well after a test drive. Thanks to all who chimed in! Sean, I hope you don't live to regret showing me how to do this. Thanks again.
Mobile Photobucket
for things I want to show in my post.
I think it has to do with the way that you have to format the link
one trick is see the thing that sort or looks like a letter with a stamp
on it in the tool bar. It's the 2nd from the end. Just click on that and
past the link address into it and you should get this.
Sean
The easy to see how it's going to look is use the GO ADVANCED button
Then use the preview each time you make a change and that way you can turn the image
the way your going to need it to be
I know that Imageshack has an editing tool on there site and I would think Photobucket does also.
The FTE one doen not let you do more than change the title of the image.
I think that FTE has a forum for testing things like you signature and other things.
That would be a good place to do the testing. Once you have the hang of it then you
don't have to keep redoing it.
Did my posting of your image show up right? If not does it need to go right,left or 180?
I take it you are using a PC. One little tool that I found handy on the PC side of things
is called View Print Pro. It can be found here VuePrint - Now Free!
It's so very handy and quick and good for quick simple edits like clocking and flipping
images. it also does a resize and that is very handy to web posting.
Let me know if you are totally bored or want more help and I'll drop it or give you more help.
I use a Mac on this end most times and only use the PC when I need to. Lynx is out of my skill set.
Sean
