1947 ford engine swap
Old Apr 29, 2011 | 12:16 PM
JordisAuto's Avatar
JordisAuto
I was wandering what kind of engine would be easy to swap into my 1947 ford shortbox (flat head 8 and 4 speed tranny). Would a 302 from a 70's ford truck fit and would it bolt to the origninal tranny? I also see lots of people have 350 chevys in them, Do these fit well? And does anyone no where you can buy motor mounts to swap in either of these engines? Thanks
Old Apr 30, 2011 | 06:28 AM
Dan Robertson's Avatar
Dan Robertson
You can do pretty much anything that you want with a torch and a welder but I wouldnt put a Chevy Engine in my Ford.
Old Apr 30, 2011 | 09:49 PM
38 coupe's Avatar
38 coupe
The only bolt in engines I am aware of are other year flathead V8s, and small block chevys. There used to be kits that came with a bell housing and front plate for the chevy. You had to run an electric fuel pump. You should be able to find the parts still. I know the bell housing is still made, the plate for the front motor mounts that goes behind the water pump should be findable as well.
I'd stick with a flathead Ford.
Old Nov 13, 2013 | 09:15 PM
HemiRambler's Avatar
HemiRambler
I can tell you that a 392 Hemi bolts in so neat it looks like Henry planned it that way!
Old Nov 13, 2013 | 11:19 PM
GB SISSON's Avatar
GB SISSON
I think it's a 'front pan/rear pan issue' with the 302 and the chev small block. I put a 302 in a ford 1 1/2 ton, but way more clearance at the front axle than the 1/2 ton. Different pans could be available though.
acevesdenise
1947 and Older Ford Trucks
27
Oct 16, 2015 05:15 AM
3twinridges
Oct 12, 2015 08:34 PM
saauvenshine
Oct 5, 2015 11:13 AM
tibbytom
Dec 18, 2014 02:36 PM
maxtegracing
WTB - Parts & other
Sep 10, 2012 10:45 PM
