You could always run a 2" shackle hanger kit with your stock leaf springs which will have an oem ride to it since your not adding a stiff leaf to your existing stock leaf spring pack. For the rear grab a stock F350 block and you should be good to go.
A little more research has revealed the availability of front leaf springs but no rears.
The stock springs went to the outfit that did the 6" lift in 2004. Long gone. The stock ford springs rode much worse than the procomp. not interested in having them back.
