Damn diff gasket!!!!
Old Aug 4, 2013 | 12:41 AM
robert_l_ross's Avatar
robert_l_ross
Had the riff fluid changed maybe 3-4 months ago...along with a ton of other work...a week ago the rear diff springs a leak.
Anyone have suggestions on a diff cover...good supplier that won't suck my wallet dry?
Old Aug 4, 2013 | 01:54 AM
Peace2Peep's Avatar
Peace2Peep
I went with the 2008 model year diff cover and even did a little custom paint job on it. They are super cheap and have vanes that help keep your diff cool. There are many aftermarket ones but I bought my Ford factory unit for about $29...how's that for cheap?
Custom painted(by me using high-temp rattle can paint and clearcoat) 2008 Ford F-250 rear diff cover:
Old Aug 4, 2013 | 02:11 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
did you use an actual gasket?
or
did you use RTV sealant to make a gasket?
hopefully you didn't use an actual gasket. there is a specific RTV for differentials. Stuff is thicker than normal and is resistant to gear oil breakdown
Old Aug 4, 2013 | 02:13 AM
wallz's Avatar
wallz
Many have gone with the 08 rear diff cover, just because of such a small cost to get the alum cover.
Remember that you will need longer bolts if you go this route as the flange is thicker on the alum cover.
The gasket is a squeeze out of a tube gasket maker when you go to replace the cover.
Old Aug 4, 2013 | 05:58 AM
Romanova's Avatar
Romanova
Good info to know as this is on my to-do list. Anyone know the replacement bolt part numbers? Or does Home Depot/Lowes have the appropriate hardware?
Old Aug 4, 2013 | 07:01 AM
Patriotic Rottweiler's Avatar
I have the Mag-Hytec (front, rear and trans pan). All three use an o-ring style gasket. I have not had any leak problems and they have been on for over a year. The best part of the diff covers is that you have the ability to check the level and add/drain without having to remove the cover. Thus eliminating the worry of the gasket leaking.
Old Aug 4, 2013 | 08:17 AM
Snowseeker's Avatar
Snowseeker
08 here as well!
Pull an old bolt out, go to hardware store and get new bolts 5/8-3/4" longer. I went with the socket head bolts and stainless washers. I didn't think of it at the time but I should have gotten stainless socket head bolts as well.
Old Aug 4, 2013 | 11:23 AM
EXv10's Avatar
EXv10
Galvanized bolts from you hardware store will work just fine.
Old Aug 5, 2013 | 09:06 AM
Reverend Jim's Avatar
Reverend Jim
Veteran: Navy
I went with the aluminum cover from Ford as well. Instead of RTV I used a gasket from LubeLocker,($21), as it's reusable. I've used them on all of my vehicles, never had one leak.
Old Aug 5, 2013 | 09:16 AM
robert_l_ross
Where is the fill bolt?
Originally Posted by Snowseeker
Old Aug 5, 2013 | 09:28 AM
Reverend Jim
Veteran: Navy
On the front, driver's side of the carrier. It's a plug with a 3/8" ratchet fitting.
Old Aug 5, 2013 | 09:39 AM
BEARDOWN's Avatar
BEARDOWN
My 2 local big box stores didn't even have the right size bolts. I went with these Armor coated bolts( Ultra Coated Alloy Stl Sckt Head Cap Screw, 5/16"-18 Thread, 1-1/4" Length)and washers(Ultra-coated Grade 8 Steel Sae Flat Washer, 5/16" Screw Size, 11/16" Od, .05"-.08" Thick) from McMaster Carr.. McMaster-Carr
McMaster-Carr
Old Aug 5, 2013 | 10:25 AM
housedad's Avatar
housedad
In case anyone is looking for stainless, I bought these in stainless from Allens Fasteners to fit my aluminum '08 cover:
Allen socket bolts:
Chrome Bolts, Stainless Steel Bolts, Metric Bolts, Socket Head Cap Screws, Grade 8 Bolts, F911 Bolts (you need 1-1/4 inch long)
Washers:
Lock Washers:
The whole shebang cost me about $17 including shipping. Shipping was $7 of it!
Old Aug 5, 2013 | 10:39 AM
housedad's Avatar
housedad
I also used this sealant. It is the sealant that Permatex designed for differentials and transfer cases. Color is gray.
Gasket Makers : Permatex® Gear Oil RTV Gasket Maker
Old Aug 5, 2013 | 10:57 AM
EXv10's Avatar
EXv10
So the mystery has unfolded; friction modifiers are what break down many sealers and cause them to leak.
