NO BOOST HIGH EGT's!!!!
Old Aug 3, 2013 | 06:59 PM
  #31
timmyboy76's Avatar
timmyboy76
you got it, Johnny. Pulled 2 other turbos, rebuilt them, installed gaskets in the collector, on one truck, and both of them have no problem, hell the one spools even more now.
The ps connector at hot side pipe,...taken care of. Have the insulation there for that reason, rest of it been deleted.
member "stinson-108" replaced his uppies and when he pulled the collector apart, the gaskets fell apart, with NO sign of leak/soot anywhere...so, that gots me think'n.
BIGORANGE....nope, havnt found the cure yet to this problem....however, with a new IPR, i DID notice a slight 1-2psi increase and it gets there quicker, but no where near, what it was, prior to turbo going boom.
Old Aug 3, 2013 | 07:14 PM
  #32
Tugly's Avatar
Tugly
Originally Posted by JOHN2001
Did you delete the ebp?
Originally Posted by 99F350bigorange
I wired mine open didn't delete it. I kept thinking my up pipes were leaking but can't see or hear anywhere it is leaking.
Not wanting to overlook anything, EBPV control arm is on the bottom and IIRC it moves toward the passenger side when closing (hissing and heating). So... you wired it to stay toward the driver side, assuming my memory is clinging to the ledge by its fingernails.
The wastegate is on top and I think I adjusted it with pressurized air... so it bleeds boost when the arm swings to the passenger side.
Old Aug 3, 2013 | 09:09 PM
  #33
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I'm leaning toward a waste gate opening too early or stuck open if everything else checked out with no leaks. My 2¢...
Old Aug 3, 2013 | 11:04 PM
  #34
99F350bigorange's Avatar
99F350bigorange
Sorry I was gone for a bit there everyone. Busy drivin half way across the state and back today. Anyways I'm going to try a couple things I got from you all tomorrow and let you know if anything gets fixed! Thanks everyone talk at ya tomorrow!
Old Aug 6, 2013 | 01:35 PM
  #35
99F350bigorange
Couldn't find anything or get any different results. In the shop today hopefully someone will figure something out
Old Aug 8, 2013 | 05:16 PM
  #36
99F350bigorange
They said need a new turbo. There is a slight catch when you spin the compressor wheel and the turbine they said looks like the gap on one side between the wheel and housing is bigger on one side then the other but it doesn't touch. Got a new turbo today gonna put it on today if it ever stops raining!! Before I do though was thinking about pulling the uppipes and making sure there is no leak again. Is there a gasket I can get from somewhere for the stock uppipes that anyone knows of?? Thanks again everyone!
Old Aug 8, 2013 | 05:53 PM
  #37
caedo's Avatar
caedo
IIRC, it's the same gasket as a Chevy 350. Otherwise you just go in to your local parts store and eyeball a match. Remember that it needs to crush a little bit.
Old Aug 8, 2013 | 09:46 PM
  #38
99F350bigorange
Pulled my up pipes off and they fell apart. What does that mean.
Old Aug 8, 2013 | 10:01 PM
  #39
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
They should "fall apart" when you pull them off. What you need to look for is black streaking up/down the pipes from the ends, which will indicate how severe the leak was.
Old Aug 8, 2013 | 10:03 PM
  #40
snakedoc's Avatar
snakedoc
i would get bellowed pipe.
Old Aug 8, 2013 | 10:20 PM
  #41
99F350bigorange
Okay. No streaking so that's good.
I would bellowed pipes but they are $900 because I have an early 99
Old Aug 8, 2013 | 11:12 PM
  #42
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Did they tell you about rebuilding your turbo for less than $100, or did they sell you a new one?
Old Aug 9, 2013 | 02:00 AM
  #43
99F350bigorange
Had already rebuilt it. They told me they could go through it but it may be a couple hours labor, at 110 bucks an hour, and they may go through it and tell me I need a new one anyways.
Old Aug 9, 2013 | 02:06 AM
  #44
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Honestly, rebuilding a turbo is less than an hours work. Maybe right at an hour if taking your time. Oh well. At least you have peace of mind with a new one.
Old Aug 9, 2013 | 02:07 AM
  #45
99F350bigorange
Put the new one in just got down and drove around a little still only saw 12 lbs. Lower EGTs though and Ill get in the interstate tomorrow and really see what it does.
