NO BOOST HIGH EGT's!!!!
I've been on here a time or two before with this issue trying again for some new ideas maybe. I don't have any boost leaks or exhaust leaks. MAP sensor is good wastegate works properly and I wired my EBPV open. Still cannot build over 10psi of boost and my EGT's area little high when I get on it. Anyone got any ideas?
Thanks in advance. |
Have you looked at your compressor wheel?
What exactly are you calling "a little high"? And you have verified with a boost leak decter no leaks including the orange boots on the spyder?
Originally Posted by JOHN2001
(Post 13399049)
Is the truck tuned? If so what tune are you running in while doing that? Also is that wot?
(Post 13399178)
What kind of boost are you seeing?
(Post 13399270)
I read that in your original post but forgot.... Do you have a fuel pressure gauge? Have you done the hutch mod?
(Post 13399378)
Have you tried unplugging the edge and looked then? Edge tunes have been known to produce very high egt's.
Originally Posted by Kdr358
(Post 13399465)
Originally Posted by 99F350bigorange
(Post 13399185)
This never use to happen but has been ever since I changed the bearings in the turbo.
Originally Posted by caedo
(Post 13399488)
Something got goofed up when you did that. Either incorrect reconstruction of the turbo, incorrect installation of the turbo on the engine, or some other thing which would be a crazy coincidence.
(Post 13399494)
I'm just lost.
