OIL LEAK!!!!
Old Jul 31, 2013 | 09:44 PM
dvldog13's Avatar
dvldog13
OIL LEAK!!!!
2003 F250 6.0L has a nice oil leak on rear of the motor high up ......can't seem to see where the leak is coming from.....any ideas would be great
dvldog13's Avatar
dvldog13
Any help would be great
Old Jul 31, 2013 | 09:51 PM
04badford's Avatar
04badford
Your going to have to spray it down and get some pics , lets hope its not the Bed Plate, you said from the HPOP area and around 1 Qt , how much oil from the last oil change did you put in and how long ago? most run 13.5 Qts should be fine and it also eliminates the Bell housing Drip, whats the IPR and ICP values?
Old Jul 31, 2013 | 10:09 PM
dvldog13's Avatar
dvldog13
Haven't had a chance to clean it off .... hopefully tomorrow morning I can get some pics.....very frustrated .....as for the oil.....just changed about 2 weeks ago....14 QTS....Schafer's 5w40......all was good....she was running great....oya I changed the ICP also
Old Jul 31, 2013 | 10:18 PM
04badford's Avatar
04badford
You may have to poke a mirror at the IPR its under the turbo slightly behind the FICM lets hope it just needs tighten. its OIL right not coolent?
Old Jul 31, 2013 | 10:24 PM
dvldog13's Avatar
dvldog13
Correct oil definitely ...... could the ICP come loose......I will check tomorrow and keep you posted
Old Jul 31, 2013 | 10:28 PM
04badford's Avatar
04badford
If your ICP is under the turbo its a good chance I thought your truck was a late build o4 if so the ICP will be on the Valve cover?
Old Jul 31, 2013 | 10:29 PM
04badford's Avatar
04badford
sorry Passenger side valve cover
Old Jul 31, 2013 | 10:32 PM
04badford's Avatar
04badford
Yep sorry you have the 03 , the ICP is with the IPR definily poke a mirror and make sure no leak electrical side of ICP or loose .
Old Jul 31, 2013 | 10:54 PM
dvldog13's Avatar
dvldog13
I'm just gonna take a half day at work an come home and take out the ICP.......20sec job.....pull it out and make sure it is seated good.....oring that is......go after it from underneath.... did it already.....probably didn't seat the o-ring good.........urgh
Old Jul 31, 2013 | 11:02 PM
04badford's Avatar
04badford
Alright ,Good luck and keep us posted
Old Jul 31, 2013 | 11:56 PM
Yahiko's Avatar
Yahiko
Don't forget to put some clean fresh oil on the O-ring to keep it from
sticking and geting a tare. Take a good look at the old O-ring for any
signs that it has been torn. If you find any replace it with a new one.
I know this part will be a pain but try to make sure that the port
that it goes into is clean also. If you missed a fragment last time
that could be the leak. Your dealing with very high pressures and
it just takes a tiny bit of crud to cause a problem.
Good luck and let us know.
Sean
Old Aug 1, 2013 | 08:04 AM
dvldog13's Avatar
dvldog13
Ok so as i sit here @ work perusing the internet on what could be wrong,i went to Advance auto web site..........that is where the last ICP sensor came from..........and I go and look up the part......... so i called them. Kid on phone looked up the part, dont have in stock but will get by 13:00........so I said fine i will be in to get it.....then a friend was looking for the same sensor and says that is the wrong part.......@ this point i am getting mad.................so I called them back and spoke with the same "kid" and he said yep two diffrent parts..........i can order it and have it tomorrow.......I said ok and then he says that will be 150.00 ........but isnt it under warranty? he said yeah but you bought the wrong sensor................like i walked in and picked it out off the shelf and walked out..........so after some discussions with the manager ......they will exchange the sensor out..........
Old Aug 2, 2013 | 06:22 AM
dvldog13's Avatar
dvldog13
Well here it is................after not being able to have internet @ home on the computer..............I have fixed the leak............ICP sensor.blew the side out.......... cant figure how to post pics......im a dumb a$$.............enough aboout me.....
Just wanted to thank everyone on the quick responses on where to look and check out as possible causes..........
THANK YOU
Old Aug 2, 2013 | 06:52 AM
mustang_309's Avatar
mustang_309
Congrats on getting her fixed and thank you for the update.
