Electrical plug ID
Old Jul 31, 2013 | 07:29 PM
Kurtboyd's Avatar
Kurtboyd
Electrical plug ID
Does anyone know what this plug is? It's located on top of the frame above the main fuel tank on my '78 F250.
Old Jul 31, 2013 | 07:43 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Looks like a standard "flat 4" or "5" trailer plug......
Old Jul 31, 2013 | 07:46 PM
Kurtboyd's Avatar
Kurtboyd
Maybe, but it's right behind the cab on the drivers side. I was thinking it was part of the camper special package?
Old Jul 31, 2013 | 08:36 PM
77&79F250's Avatar
77&79F250
Duh I read fuel tank and figured rear one...my bad. And wire tags or can you trace it back to a power source?
Old Aug 1, 2013 | 09:04 PM
fmc400's Avatar
fmc400
MSEE
Can you make out any of the wire colors?
Old Aug 1, 2013 | 09:10 PM
77&79F250's Avatar
77&79F250
Kurtboyd, fmc400 aka "the man" just stepped in to help and he should have the answer for sure.
Old Aug 1, 2013 | 09:14 PM
Kurtboyd's Avatar
Kurtboyd
I'll check to see about colors.
Old Aug 2, 2013 | 03:40 PM
Kurtboyd's Avatar
Kurtboyd
I tested it with my meter. It's hooked up to signals, brake lights, and running lights. My guess is that you'd plug your camper into it behind the cab to run lights on the camper. As you can see, I won't be using it for that purpose
F350blueberry
6.7L Power Stroke Diesel
Jul 30, 2012 10:05 PM
ProActive
All Things Towing
Aug 4, 2009 11:35 AM
oem78
Nov 1, 2006 12:16 PM
highboy1975
Dec 6, 2004 04:34 PM
Fireman57
Nov 7, 2001 10:21 PM
