Nebraska Chapter Join Chapter, Leader: 97nukeford
Nebraska's official August BS thread
Old Aug 28, 2013 | 11:22 AM
  #1501
67nukeford's Avatar
67nukeford
Veteran: Navy
Originally Posted by cowboywanabe
George - Since Charlie told me to watch his back while he's gone, you'll have to follow my advice... Get some duct tape and a flash light with a red lense. Tape the flashlight on the side of the truck next to the tail light. Have someone sit in the bed of the truck and turn the flash light on and off as needed when you stop or signal a turn.
Problem solved!
That should work like a charm!!
Old Aug 28, 2013 | 11:27 AM
  #1502
GLR's Avatar
GLR
Duct tape is the only tool Rob is allowed to use.
https://www.google.com/search?q=man+...ml%3B200%3B339
Old Aug 28, 2013 | 11:29 AM
  #1503
dustybumpers's Avatar
dustybumpers
I'm baaaaack........
Old Aug 28, 2013 | 11:30 AM
  #1504
Sparky83's Avatar
Sparky83
hey braskie..
Old Aug 28, 2013 | 11:38 AM
  #1505
67nukeford's Avatar
67nukeford
Veteran: Navy
And I question giving him that.....
Hey Charlie!
Originally Posted by Sparky83
hey braskie..
Sup' Ginian?
Old Aug 28, 2013 | 11:40 AM
  #1506
Sparky83's Avatar
Sparky83
hey pat... just tryin to get through wednesday... you?
Old Aug 28, 2013 | 11:46 AM
  #1507
GLR's Avatar
GLR
Cleaner? and wiser?
Old Aug 28, 2013 | 11:47 AM
  #1508
big-ugly's Avatar
big-ugly
hey guys, good news! I thought I had a bad throwout bearing, slave cylinder, etc, etc.... turned out to be a bad u-joint on the rear driveshaft!
Old Aug 28, 2013 | 11:48 AM
  #1509
dustybumpers
Cleaner? and wiser?
Hey. Must be, I'm on the same couch, and not getting yelled at
Old Aug 28, 2013 | 11:54 AM
  #1510
67nukeford's Avatar
67nukeford
Veteran: Navy
Hey Brandon. That's great, gotta like an easy fix!
Old Aug 28, 2013 | 12:04 PM
  #1511
big-ugly's Avatar
big-ugly
No doubt! $30 for 2 u-joints with lifetime warranty, couldn't be happier I was prepared to spend $300+ on a new clutch kit, throwout bearing/slave cylinder, resurfaced flywheel, etc... Now all I gotta do is change out a u-joint.. Decided to do both while I was at it.
Old Aug 28, 2013 | 12:14 PM
  #1512
67nukeford's Avatar
67nukeford
Veteran: Navy
Yeah, no sense taking a chance with the other one.
Old Aug 28, 2013 | 12:38 PM
  #1513
big-ugly's Avatar
big-ugly
The other one is still good, I will just save it as a spare in case I break one doing something stupid
The one that is bad is the original sealed u-joint.. I couldn't believe that with 198k miles on the truck!
Old Aug 28, 2013 | 12:42 PM
  #1514
67nukeford's Avatar
67nukeford
Veteran: Navy
I think I got about 170K out of the ones on the 97.
Old Aug 28, 2013 | 12:43 PM
  #1515
GLR's Avatar
GLR
That's good news Brandon. With the money saved you can????
Got TS fixed on the 86 found a section broken underneath the cab where the insulation was pierced with a test light. Probably when the hook up for the 5th wheel was done who knows when.
