Can anyone tell me how to get steering box off column without damaging either one. Would like to sell box after separating it. Will be keeping old column for project. thanks for any info.
Steering shaft and worm (3524) is a one piece assembly, goes directly into the gearbox.
I know this post is 3+ months old, but I just came across this same situation this week - bought a column, but new front end will be power steering.
I guess my question for you is "what did you do to connect the old column to the power steering after removing the box"?
I have the box somewhat apart, the wheel off, but have not removed the shaft/worm yet, as I was not sure what stays and what goes off this older unit. Any advice is most welcome
Thx...
You'll have to get a u joint of some sort. Cut the worm off and put the u joint in it's place. CPP, No Limit, etc. will have what you need. You'll also need to get a piece to go between the u joint and the front end. And then prolly another u joint. I'm not sure, but I think you'll also need something to hold the column in place.
