need help please
Old Jul 30, 2013 | 01:34 PM
stonemason's Avatar
stonemason
need help please
my truck died like you turned the key and will not start now this is what's been done new cps from ford fuel bowl un plug #22 fuse good and replaced to make sure . now I thought the pcm was shot so I got a good pcm and still will not start . It will crank but the wts light will not come on . what should I look at now ? no code reader
Thanks
Old Jul 30, 2013 | 01:49 PM
glovemeister's Avatar
glovemeister
Are yall getting smoke while cranking? What about tach movement? Have you verified that you have sufficient oil in your HPOP reservoir?
If you have a chip have you unplugged that and tried without it?
Have yall verified that you have have good power at the batteries? Need at least 10.5 to get er going.
Just because I have to ask... Are you sure you unplugged your fuel bowl heater and not your IPR?
Old Jul 30, 2013 | 02:07 PM
stonemason's Avatar
stonemason
Yes the fuel bowl unplugged and no the tac does not move an no smoke Thanks for the help I need a lot ha
Old Jul 30, 2013 | 02:09 PM
stonemason's Avatar
stonemason
OOH took the chip out still the same I thought with out the wts light the truck will not fire ?
Old Jul 30, 2013 | 02:31 PM
madpogue's Avatar
madpogue
Check/swap the PCM relay. Also check maxifuse #9 (50A, IIRC) under the hood.
Old Jul 30, 2013 | 06:34 PM
stonemason's Avatar
stonemason
ok checked the relay and # 9 fuse good .May be bad cps from ford I did order one more just to check wont hurt thanks guys your all very help full
Old Jul 30, 2013 | 06:40 PM
glovemeister
Are yall actually testing fuses with a meter or just visual? Sometimes they may pass visual inspection, but with a meter they show up as bad.
Old Jul 30, 2013 | 06:56 PM
stonemason's Avatar
stonemason
Yes with a meter are the pcm relay in the fuse box or the two along side the fuse box.? I did switch them out thanks again
Old Jul 30, 2013 | 08:59 PM
madMatador78's Avatar
madMatador78
What kind of CPS did you put in? Was it from a parts store or from International or Ford?
International and Ford are the only ones to use. I've been told that parts store ones (yes even napa) can be bad out of the box.
Old Jul 30, 2013 | 11:39 PM
madpogue's Avatar
madpogue
You could put an oreo cookie in place of the CPS, and the WTS light would still come on. If the WTS light isn't coming on, your problem is upstream. PCM, PCM relay, main power, ignition switch, etc.
Does anything else dependent on KOEO work? HVAC blower, directionals, etc?
Old Jul 31, 2013 | 11:56 AM
stonemason's Avatar
stonemason
Ok here is the following all fuse good checked with meter changed pcm with a good one switched out relay. new gpr new. cps from ford. fuel bowl discon and still no start am going to try a new diod cause I am not getting a reading am at my wits end here
dioxippus
35
Jul 24, 2022 09:19 AM
GraysonM
Mar 29, 2018 06:45 PM
mjtpolice76
Apr 5, 2014 07:54 PM
seanj5202
31
May 26, 2011 09:32 AM
Mroz17
Mar 24, 2010 07:04 AM
